April 13, 200421 yr What is the belt sizes for the front of the engine on a carbed EA82 engine. it has A/C, the belt that broke goes around the power steering, A/C, water pump and crank, then i also need the size for the other belt so i can replace it now also. it goes over te crank, power steering, A/C, Alt, and the tentioner. i need these sizes soon please, Thanks, Shean
April 13, 200421 yr Well, if you take the old belts to the parts store it will help them to replace it. Also, them knowing the specs of your car will give them a clue also.
April 13, 200421 yr Author the problem is that they are on my car, another set, and i need that car to get to the parts store, and the ones that broke, are on the road somewhere. oh well, i guyss we will have to just try them in the parking lot. Thanks, Shean
April 13, 200421 yr Maybe its just me.. But I just go into the parts store and tell them what I need (make, model, year, accessories) and they give me the right belt...
April 13, 200421 yr take the old belys with you to the parts store. there are tree different setup that i have seen. there is the round compressor with the alternator outboard there is the square compressor with the inboard alternator, and outboard alternator those models with the INBOARD alternator use both the SHORTEST and LONGEST belts of any setup
