Subaru XV - Ute ...
i would pay so much money for an xv ute with a diesel and manual trans. i would trade my wrx for it in a heartbeat.
Edited by subyrally
  • 2 weeks later...
  • Replies 77
  • Views 34.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Hi This is Jerry,i need a new Subaru my 85 hatch has 315 thousand miles on it. This XV ute is just what I want to buy. I would really like the ceo of Subaru to read this. I would buy serial #1 if I co
  • Rear End Cast ...   Quick one for last bit on rear end :   & removed :     Do Note that I've marked up where tail gate has to fold down & so will be removing that bit ...   Ok -
  • Ok - Time for an update :   I've nearly finished modelling, just added some final trims & did some preliminary renders :               Hope to do some hi res images in photos
First cast ... B)
Ok - finally got round to do some casting, here are some of the results :
Front end :
Rear window :
And removed ready for next bit :
'Pug' mould for rear end :
More to come .... :)
Cheers, Bantum ...
Edited by Bantum
Top Cast ... :ph34r:
Next up is the top half of cast :
Casted :
& Removed from Mould :
De 'pugged' & Ta-Da - a ute is staring to Appear !
Still have the lower half to do yet ...
Cheers, Bantum ...
Edited by Bantum
Rear End Cast ... :wub:
& removed :
Do Note that I've marked up where tail gate has to fold down & so will be removing that bit ... :)
Ok - that's it for now, back to casting ... :)
Cheers, Bantum ...
Edited by Bantum
  • 1 month later...
Ok - had time to do some more work on this :
Note : Working with these to make  a more realistic XV wheel ...
Next bit :
Back to it  ... ;)
Cheers, Bantum ...
Edited by Bantum
  • 3 weeks later...
Some results from more casting :
Had to add a bit in the middle to level it out ...
More prep work :
Ready for casting :
And no - its not milk in the bottle ... :P
Done :
Awaiting drying ... :) hmmm will have to add some bolts later ...
Cheers, Bantum ...
Ok - next bit to bring up to date ...
Last bit of casting dried :
Some fixings :
& holes Drilled :
More Securing :
Nearly done :
Cheers, Bantum ...
  • 3 weeks later...
Just received some more bits for this project ...
Some Stealth Mounts :
Some Racks :
& Test Fitting :
Got some more bits on the back burner too !
Cheers, Bantum ...
Edited by Bantum
  • 3 weeks later...
Nearly done with wheels ...
Last bit of casting :
And all apart :
And the aim is to make 'em look something like this :
Marked out Ready to cut :
Still more to do on front side ... :twisted:
Cheers, Bantum ...
  • 2 weeks later...
Sorry to say there will be a bit of a hold up on this project due to my back surgery ... :(
So here is something else to tide you over until then :
More details on this beast can be found here : http://www.ausubaru.com/forum/showthread.php?t=23869
Cheers, Bantum ...
Edited by Bantum
Finally got round to finishing this drawing I had started ages ago :
Something for the Brumby boys to mull over ... :P
Cheers, Bantum ...
Edited by Bantum
Certainly Haight,
My background is in Architecture & Design ... So not a traditional industrial designer per say, but I still know how to draw ... :)
You can see more of my work in the photo bucket links below ... ;)
Cheers, Bantum ...
  • 3 months later...
Hi all, Bit of an update for you :
Enjoy ... :)
Cheers, Bantum ...
  • 2 months later...
Added some colour to the previous drawing :
I'm working towards to making a Scale Paper Model, so every one can have one - you just need to print it out & assemble it ... :)
Give me a few days to work it out though ... :cool:
Cheers, Bantum ...
Edited by Bantum
Paper Model ...
Ok - Here it is, a paper model of the XV-Ute :
Edit : I'm working on a high resolution copy ( PDF ) & I will put together an assembly sheet next ( for those 3D challenged ) ... :D
Cheers, Bantum ...
Edited by Bantum
  • 2 weeks later...
Paper Model PDF ...
Ok - I've redone the model & have up loaded it here  :
Subaru XV-Ute Model
Working on an Assembly sheet now, will post that when done ... :D
Cheers, Bantum ...
Edited by Bantum
Paper Model Done ...
Have now completed making the Paper Model ... :)
More on FB : https://www.facebook.com/media/set/?...8670681&type=1
Welcome to make your own ( It's not too hard ) and then take into your local dealer & say I want one of these for real ... ;)
Cheers, Bantum ...
Edited by Bantum
VERY COOL!!!!!!   Thanks so much for this endeavor.
Got something to put the Paper Model in :
Cheers, Bantum ...
Edited by Bantum
  • 2 months later...
XV Wheels ...
I didn't get very far with trying to cast them, so I ended up going and getting some 3D printed - following is the trial example :
Loaded up :
The Printers :
Printing :
Measured up :
Front :
Back :
Cheers, Bantum ...
Edited by Bantum
Then test fitted them to the TT-01 Chassis :
Fitted Strait up :
Spacers :
Note : the larger one will need longer shaft ...
I may have stuffed up the offset, will have to wait until I've done the body to see how well it sits up against the fenders ...
Ciao, Bantum ...
  • 8 months later...
3D Download ...
For those wanting to print one of these babies out, I have now uploaded it to thingiverse :
Download here : http://www.thingiverse.com/thing:946554
Slowly progress is being made on the scanner, so will be able to do some more on this project when completed ... :D
Ciao, Bantum ...
  • 9 months later...
Funds ...
Thinking of possibly doing some crowd funding for this project, however there's a quiet a few sites out there so not sure about it ... :blink:
What do you guys think would be best option ?
Cheers, Bantum ...
Edited by Bantum
Update ...
Time for a bit of an update, as it's been a while since I've worked on this ... :/
Took the paper model out for its first showing the other day :
 IiRBBswBEYcXYlHthx4RWDLw4vfrc2z23Z4BYu6asR6y4Ta1E0GxwXd2u8X-dYatU_zLSnXmZr723O84hVYRGdKJn5TFlZfcB8jx-3rX0XtDLglHHQrlzn9A0eH6n0iUhCAm1L3hoSktqfNhmpBbNiM3esc9cW6ZfLO6_p_rkpmjj0PjlBYV4vfccT07XHCbqsphHX7NgHftAZGkjlhcdrqPSc9dUkqGxLpMjP82epuOqxOY2ZFlCj2jSymIekQQB19UcnifqHwdgrSxRyIiDSwtWU4xeBO6F3qQ5sT4H8XLubVACCxhiCO93jkD6FoXOiw9QWpDQLKRXeE5zn6up__2wJhT3ESW5vkxMLe7QuoESXovs7XO6_jW383Lc5drliYH0pdQOKzSx9gyppNy_EsEdweHbzM1mZ6fHeClV2PO0r_qj2MA69X2HcFH6_TXLInrXaa-mt9tppMdnkv80nTVubQ0lt_3pQ_yNvT4Udd3mZgspHbdjl4AKAV2VjxiocDv-IFAfn4ion-4SOfZsGJ72uVNeK1-ZFHPF4M2zwSSfbX_rLabtBKqkaS2r-rUdH5ohfCuOiUnXYWfoOaZuTaG9Ncl-n-6oijSjApnpY_DBEvm=w920-h690-no
Didn't win anything but ... :(
Was doing some research on an updated front end, something like the look of the 'KenStyle' as shown elsewhere on here.
Might see if I can get them loaded up on the model ...
P.S. - I may also have found a willing hand to make the full size prototype ... :)
Will post more when I have something concrete confirmed ... :icon_mrgreen:
Ciao, Bantum ...
