March 21, 201313 yr I have a 94 Loyale wagon and I have a quick question about the exhaust. How wide is the pipe? I plan on buying a cherry bomb. How wide should i buy?
March 21, 201313 yr Author it's been awhile but i think it's 1 7/8".... Ok thanks! I've been hearing 2" but I'm not sure
March 21, 201313 yr It depends on if it's factory original. My Brat was 1.75 at the cat, but the mid pipe was 2. It would be best to go out and measure before you order. Edited March 21, 201313 yr by Speedwagon
March 23, 201313 yr IIRC, I stuffed a cherry bomb/thrust glasspack on my 86XT (exhaust from an 88 turbo wagon) and the 2" ID glasspack fit PERFECTLY over the OEM pipe just before the muffler inlet. No adapter or anything needed. (I DID have to ghetto rig some hangers since I was too lazy to weld some rod steel for hangers.. some hole steel, two bolts and the rubber isolators worked pretty well! XD and it was just a 24hr Lemons car, so I felt less guilty about the poor hanger quality )
September 16, 201312 yr i have herd when you do throw a glasspack on it can mess with the comprestion is that just a myth or whats up? i ask because i was thinking on putting one on my 81 GL the 1.8L.....
