March 27, 201313 yr Hi all! Its been a few years since I have posted here but hello to all! I am involved on a team at my university that is building a contraption of sorts. I was wondering if I could be pointed in the right direction about the following information: What is the OEM subaru # for the power steering pump used on all the EA82's of the 80's?? Does anyone know who the ACTUAL manufacturer is of this pump? (Who did subaru buy them from?) Does anyone know the displacement and relief valve pressure of this pump? We did some measurements a while ago to get an ESTIMATE on displacement per revolution, but we still have yet to actually know. At present this pump is in the process of being modified to be the fluid source to a highly modified Toyota automatic transmission that has had the torque converter removed. Thanks everyone!
March 30, 201313 yr I don't know who made it, or the OE number. The XT's pump is slightly different from the L-series pumps; visually they're nearly identical, but apparently there's a difference somewhere according to various internet sources that list parts for one but not the other. pskits.com sells a pump rebuild kit for the XT. According to my '87 XT FSM: *Output: 5.9 cc, 0.360 cu in /rev *Relief pressure: Turbo/MPFI: 924 psi Others: 640 psi *Hydraulic flux: 700 RPM: 7.4 US qt/min 3000 RPM: 2.6 US qt/min *Regular pressure: </= 142 psi *Relief pressure and working pressure: 853-1067 psi
April 4, 201313 yr hi, the ea-82 pumps had an early (85-86) AND A LATE (87-ON) , they look similar but are "different inside" and the parts do not interchange . depending on which you have, you'll need the correct rebuild kit. the xt pumps also have early and late versions, again different parts internally , i think they might interchange with the other cars as far as fit ,but may be valved different from the other ea82 cars, as the pressure specs are different for xt's, and other ea82's , also the shafts had pulleys for flat ribbed belts. Edited April 4, 201313 yr by ruparts
April 5, 201313 yr Since someone already posted the specs, the OEM is Atsugi. Just pulled 2 off an 88 and a 93 (both v-belts, but the v-belt and serp belt pulleys interchange) and the XT used the same pump, but had an offset reservoir to clear the hood.
April 5, 201313 yr remote trans oil pump tell me more i think if you moved up to newer pump could get more flow and preshure there were many different pumps in subarus depending on engine size weight of car and engine load
