April 17, 201313 yr Pics Of the p.c.v valve on my 80 ea71 (1600) It should be the same on most of the ea series engines. I hope this helps.
April 17, 201313 yr that thing inside is supposed to move back and forth right Yes. Kind Regards. Edited April 17, 201313 yr by Loyale 2.7 Turbo
April 18, 201313 yr it should rattle when you shake it, and only allow air to flow 1 way when you blow into it.
April 18, 201313 yr it should rattle when you shake it, and only allow air to flow 1 way when you blow into it. Yep that's how you test it, if it doesn't pass replace it.
