building a buggy
wanting to build a rear engine buggy need to learn some before i get started
first other than subarugears.com any other way to make a subaru trans go backwards? flipping over like vw ?
what is the best subaru transmission to build a 4x4 rear engine buggy gl/loyal/legacy/impreza?
i dont need a 5 speed 4speed is fine
ok and now for the lil tid bit to make every one hate me rather than spend money i dont have 2 subarugears.com i was thinking of putting a ..... (sorry!)
hondalildevil.gif engine to the subaru trans because they run counterclockwise and subaru run clockwise
then i still need to mount the subaru diff and suspension into a sandrail
So how long u think the diff will last running backwards? Will the gears fail being turned backwards?
so looks like im going to be running a L series hi lo 4 speed from subruise
and am getting tone of help on this from him
  • Replies 58
  • Views 33k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Run on sentences and mispelling are making it really hard to tell what you are trying to accomplish?   Are you trying to use Subaru rear axles in a front hub?   Why not just use Legacy rear axles
  • 1 Lucky Texan
    1 Lucky Texan
    I think the Aussies build plenty of soob powered rear-engine sandrails, dunno how cheaply it could be done but, I'd think spending a little to keep as much soob stuff that bolts up easily would be bet
  • ivans imports
    ivans imports
    +1
Posted Images
  1. also im going to be running the tires i already have that are new 34 9.50 r15 ss tsl
Edited by apintonut
ok so subrise hooked it up with allot of the parts.  im going to need, but found my first few problems,
the steering knuckle wont work so i need something from a different car.   i need a list of where to start.   so i went on to rockauto.com looked up a front wheel bearing for a 88 gl.   this is what i got all these cars take the same bearing
now i just hafta find the one that has upper and lower control arms and fit the sub hub into it
ALFA ROMEO SPIDER (1969 - 1994) DODGE 2000 GTX 1989 DODGE COLT (1988 - 1994) DODGE COLT 100 DL (1989 - 1991) DODGE COLT 100 E (1989 - 1992) DODGE COLT 100 LX (1989 - 1990) DODGE COLT 200 DL (1989 - 1990) DODGE COLT 200 E (1989 - 1992) DODGE COLT 200 GT (1991 - 1992) DODGE COLT 200 LX 1989 DODGE COLT DL (1987 - 1990) DODGE COLT E (1987 - 1989) DODGE COLT GL (1990 - 1992) DODGE COLT GT (1989 - 1990) DODGE COLT PREMIER (1987 - 1988) DODGE COLT SE 1992 DODGE COLT VISTA (1987 - 1991) EAGLE 2000 GTX (1991 - 1993) EAGLE SUMMIT (1989 - 1996) EAGLE TALON (1990 - 1994) EAGLE VISTA (1989 - 1991) FORD COURIER (1972 - 1982) HYUNDAI ELANTRA (1992 - 1998) HYUNDAI EXCEL (1986 - 1994) HYUNDAI PONY (1986 - 1987) HYUNDAI SCOUPE (1991 - 1992) HYUNDAI SONATA (1989 - 1998) HYUNDAI STELLAR (1986 - 1987) MAZDA B1600 (1972 - 1976) MAZDA B1800 (1977 - 1978) MAZDA B2000 (1979 - 1984) MAZDA B2200 (1982 - 1984) MAZDA ROTARY PICKUP (1974 - 1977) MITSUBISHI CORDIA (1984 - 1988) MITSUBISHI ECLIPSE (1996 - 1997) MITSUBISHI MIRAGE (1985 - 1996) MITSUBISHI PRECIS (1987 - 1993) MITSUBISHI TREDIA (1984 - 1988) NISSAN 200SX (1977 - 1982) NISSAN 210 (1979 - 1982) NISSAN 240Z (1971 - 1973) NISSAN 260Z (1974 - 1975) NISSAN 280Z (1975 - 1978) NISSAN 280ZX (1979 - 1982) NISSAN 310 (1979 - 1982) NISSAN 410 (1963 - 1965) NISSAN 411 (1963 - 1967) NISSAN 510 (1971 - 1981) NISSAN 520 PICKUP (1965 - 1968) NISSAN 521 PICKUP (1969 - 1972) NISSAN 610 (1973 - 1976) NISSAN 620 PICKUP (1972 - 1979) NISSAN 710 (1974 - 1977) NISSAN 720 PICKUP (1980 - 1982) NISSAN 810 (1977 - 1981) NISSAN B210 (1974 - 1978) NISSAN F10 (1976 - 1978) NISSAN MAXIMA 1982 NISSAN SENTRA 1982 NISSAN STANZA 1982 PLYMOUTH COLT (1988 - 1994) PLYMOUTH COLT 100 1990 PLYMOUTH COLT 100 DL (1989 - 1991) PLYMOUTH COLT 100 E (1989 - 1992) PLYMOUTH COLT 100 LX (1989 - 1990) PLYMOUTH COLT 200 DL (1989 - 1990) PLYMOUTH COLT 200 E (1989 - 1992) PLYMOUTH COLT 200 GT (1991 - 1992) PLYMOUTH COLT 200 LX 1989 PLYMOUTH COLT 4X4 1992 PLYMOUTH COLT DL (1985 - 1990) PLYMOUTH COLT E (1985 - 1989) PLYMOUTH COLT GL (1990 - 1992) PLYMOUTH COLT GT (1989 - 1990) PLYMOUTH COLT PREMIER (1985 - 1988) PLYMOUTH COLT VISTA (1985 - 1992) PLYMOUTH COLT VISTA SE 1992 PLYMOUTH LASER (1990 - 1994) PORSCHE 356A (1956 - 1958) PORSCHE 356B (1960 - 1963) RENAULT CARAVELLE (1965 - 1966) RENAULT DAUPHINE (1965 - 1966) RENAULT R10 (1967 - 1971) RENAULT R12 1971 RENAULT R16 (1969 - 1971) RENAULT R8 (1965 - 1966) SUBARU DL (1974 - 1989) SUBARU FE 1979 SUBARU GF (1975 - 1979) SUBARU GL (1985 - 1989) SUBARU GL-10 (1985 - 1989) SUBARU GLF (1980 - 1982) SUBARU JUSTY (1988 - 1994) SUBARU LOYALE (1990 - 1993) SUBARU STANDARD (1976 - 1987) SUBARU XT (1985 - 1987) TOYOTA LAND CRUISER (1969 - 1975)
Edited by apintonut
Why not just use Legacy rear axles and knuckles?  That knuckle is already setup with the pivots for a multilink rear end.
yah but then i would have 4 reverse gears and one forward and be runnig a junk vw engine
Wrong way round.  He's saying use a Subaru engine and a VW gearbox, that is already setup for rear drive.
Or, use a FWD subaru trans, and put the engine in front of it, with the trans sticking out the back.  A FWD, 4EAT automatic or a FWD legacy/imp 5spd would be awesome, nice and short too not alot of rear overhang.
I think the Aussies build plenty of soob powered rear-engine sandrails, dunno how cheaply it could be done but, I'd think spending a little to keep as much soob stuff that bolts up easily would be better than getting crazy with a lot of mismatched stuff.
Apintonut, I assume you're either unsure of what you want or you're taking the P
i know exactly what i want. however no one else has done it yet.  . im just going to hafta be the first that dose it,  have a feeling it will be copied many times once i work out all the bug for every one else
1) if i had 1500$ + shipping.  i would just buy a set of gears from subarugears.com and run a subaru engine and have done with it.
2)if some one had already worked out how to make a subaru engine run backward's with parts that are easy to hand it would be built
3)if syncro where all over the place ide use that and a adapter plate and a pinto engine or bus trany where cheaper ide build what my last buggy was a .091 trans and pinto engine or maybe subaru
Edited by apintonut
sorry some of my pics wont upload this is first mock up
Edited by apintonut
this is more or less what i had in mind more power and bigger tilres
why not build one with normal soob layout? Engine in front?
shorten the driveshaft, put fuel cell and move battery in the back.
I dunno
  • 2 months later...
progress update;
no progress looks like subarugears.com is the only way to do it
check this out
http://www.thesamba.com/vw/forum/vie...er=asc&start=0
that link is close to what i had in mind just in a rail frame
how ever im still looking for a cheaper way to build it looking for a ring gear that is the same amount of teeth and same pitch just revers angle i may resort to the same path as todd of subarugears.com and have it made but only the ring gear
this has potential to be a little weaker than subarugears.com 's parts but not by much i think.
they are running the rear diff in the front just flipped over no mods to the internals at all
made a little bit of progress to day i know what im looking for via specs
subaru is 37 or 39 tooth ring 12 tooth pinion right cut
i need to find the same thing out of something els that is 37 or 39 tooth left cut
witch i am finding but audi has 10 tooth pinion and Chrysler has an 11 tooth pinion........
one would think this would be easy this day in age to just type in what what u want and tell you what car it was used in
how ever its more like pic a car that u want to check and search for the ring gear get all the part number then search and search and search for the specs on that part
much thanks go out to merlin owner of Transmission parts for the masses
877-771-3372
http://mmerlinn.com/catalog/silver_m...01/jtr01_f.htm
who also thinks the RING gear i seek is out there and just hast to be found (insert lord of rings joke here)
p.s. the next one to check is vw and after market vw mid engine parts to see if any one already makes a ring gear so that you can run mid engine with out flipping the whole transmission over
and Porsche
so i bout a bunch of gl stuff and now it looks like i need all legacy stuff but subrise hooked it up on the price so not a big set back
and Porsche
look, as we have all said - if you want to go mid-engined you can use the Suby engine and gearbox as it is. If you want to go rear engined there are many firms who will sell adapters to mate suby engines to VW gearboxes. What's the problem or is this just a troll post?
You say 'no one else has done it yet' well, I doubt that very much.
well vw trannys are getting to RARE they are a thing of the past. vw trans is off the table 100%. stop.  YES I WANT 4X4!!!! that would be way cool for my use of the vehicle.
if i had 2200$ for ring and pinion from subarugears.com , would not have this conversation.
i need a cheaper way to do it. that would take a ring gear that cut to make it work. im trying to find that ring gear already built for another purpose to fit into my tranny
what am i trying to build? really??? did u see the vid of the 4x4 go cart? did u see the pic of my frame? did u see i posted a link saying this is the same as im trying to build just in the frame i have?    if so how is that u no comprehension what im attempting to build? do you just have a big stick and go around here trolling  trying to stir a up $#!+
how ever if i mist took the rude tone of your reply im sorry but calling me a troll is very much not welcome
i think to get any further im going to need full specs for a 92 legacy stock ring gear.
dose any one know where to get this info?
OK, my apologies - it's just that every suggestion made here has been rejected by you. So, lets get this straight, you want a rear engined 4X4 buggy. Fine, buy a rear-engined VW synchro and use the runing gear from that or just build your driveline using a transfer case. But you do realise that a rear-engined 4X4 buggy will have very little weight over the front wheels.
your right there is other ways to build it the most likely is a transfer case for what i want. a synchro is out if the question the trannys for those go for about 5000$ for a used one in my neck of the woods thats more than 1500$ @ subaruhears..com  i do appropriate the input but to build what i want  for the price i want its going to take somthing done a different way if this looks to turn into a 6k toy ill just buy the one of the buggys in the vid up top but really my budget is about 2k for this toy.  i think this is do able im going down to pia motor sports right now they are going to give me an needed ring gear im going to take around to some shops and see if we can find its backwards cousin
very little weight over the front wheels is fine  however i think it will have more than u think i bet is is 60/40  and the hole rail will be light about 1600-1700lb with me in it
my last rail was considered heavy @ 1750 with me in it, most the newer rails are coming in about 1200lb but cost big $$$$
Thanks for the clarification - further confusion was caused by the video you posted; that buggy was not rear engined but mid-engined. Now we know what you want we can help. Be good to see some pics as the project progresses, good luck with it.
edit:
Hey, wait a minute - I've just looked at the pic you've posted above - that's mid-engined too!
I give up (as have everyone else and now I see why)
Edited by NickNakorn
