Robepktt Posted June 10, 2013 Share Posted June 10, 2013 I need some info on how to remove the rear brake calipers from my 98 subaru legacy outback wagon. Quote Link to comment Share on other sites More sharing options...
davebugs Posted June 10, 2013 Share Posted June 10, 2013 Been a while but if you search a little bit you'll find the info here. Remember those rotors have "drumette's inside fo rthe parking/Ebrake cables and shoes. Quote Link to comment Share on other sites More sharing options...
ocei77 Posted June 10, 2013 Share Posted June 10, 2013 here is ref to FSM. Use the 97 one. http://www.main.experiencetherave.com/subaru_manual_scans/ Not sure if you have one or two bolts (14mm) on a 98. If not 2, the topmost bolt is only a sliding pin. Remove both, clean and relube when reinstalling. Need a c clamp to compress the piston back into the bore. A youtube search will have some diy's. O. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 10, 2013 Share Posted June 10, 2013 it's really easy. with the wheel off it takes one or two 12mm bolts (there are two different styles - yours is probably 2 bolts) and the caliper comes off. there's no need for directions in removing the caliper it can literally be done with your eyes closed it's so easy. Quote Link to comment Share on other sites More sharing options...
