August 29, 201312 yr My mechanic is changing my 2.5 engine for a 2.2 engine in my 1999 Legacy Outback. The job is almost complete but he is only getting fire to two plugs. He changed the coil to a 2.2 coil, but then he had no fire at all. Please help. I need my car back!
August 29, 201312 yr it's all plug and play - there's nothing special about it (well unless there's something we don't know, i have to assume some things since you don't tell us what kind of EJ22). there's nothing "swap related" that should be causing this - there is something wrong with the installation (don't tell him that, i just can't think of a better way to say it on the fly) - like a bad ground or plug disconnected, etc. any Check engine light? read the check engine codes with a scanner - what comes up? was the timing belt/engine tested or is this a used/unknown engine? check all plugs, MAF, cam sensor, crank sensor, igniter, and ground wires. exactly which EJ22 did he use - year, make model?
August 29, 201312 yr There is no such thing as a 1999 Legacy Outback with an EJ22. I am assuming that it's just an engine from a 1999 Legacy. If the engine you have is an EJ222 (phase 2), I believe that they are not plug and play with the EJ25d that was in your Outback. It sounds like your mechanic should have chosen an engine to swap in that was a model year older. That would have completely eliminated having to modify the wiring harness to get it to run.
August 29, 201312 yr If he had to splice wires he did it wrong. Have him pull the engine, pull the heads, install 1994-1995 heads on the shortblock and use the intake from a 1995 to correct it. That would be the perfect solution as its 8 bolt case. Be sure he uses the older head gaskets as well (1995 EJ22).
September 2, 201312 yr what year car are you working on? is the ej22 from a 99 legacy, or 99 impreza outback sport? either way, the 99 ej22 is a phase 2 engine and is not swappable into a 96 - 99 ej25 car.
September 3, 201312 yr I can get a 97 2.2, so that would be plug and go? yes, but: 1. any 1996-2001 EJ22 will also require the exhaust manifold - it's single port. it bolts right up. those can be hard to get as yards often wont' sell them. 2. if it doesn't have EGR it'll have a check engine light. will install and run fine, but if your state requires emissions you may have issues. that being said there is a simple work around to that issue posted here, familiarize yourself with it. 1995 automatic EJ22's are direct plug and play swap, have EGR, and have dual port exhausts. 1995 manuals have dual port exhausts but not EGR - need the EGR work around. 1996-1998 EJ22's need the exhaust manifold and EGR varies with no known indicator to know whether it has it or not- just have to look with your eyes. but someone did find a workaround and posted it here, so that's not a big deal if that works. i haven't done it yet.
September 6, 201312 yr So what engines actually came in the 1999 Legacy Outback? "Engine", not "engines" - there's only one offered for a 99 Outback: EJ25D (Phase I Dual Overhead Cam - DOHC, EJ25) http://www.cars101.com/outback_archive98-99.html Edited September 6, 201312 yr by grossgary
September 6, 201312 yr Over your heads yikes never ever cut any wires on engine harness can O worms the 99 harnes and intake is not the same the ealy 99 engine uses a idle motor that uses the signal from #1 injector without it no injector pulse on cly 1. I use a single cam engine with that harness but idle motor passage had to be welded up and idle motor had to be pluged in not hooked up. and had to use engine harness from the 99 ej25d and coil pack. It can be made to work but you better know what your doing !
September 6, 201312 yr So what car did the EJ222 and Ej223 come in? Legacys (not outbacks) in 1999 Legacy brighton, L, 30th anniversary And 1999-2001 Imprezas (except RS). it's confusing because the FIRST year of that engine came in some (not all) of the LAST of that body style.
