SJR Wheeler Build 90 Legacy Wagon 2013
fabricate a long arm kit for the front with custom axles
  • Replies 115
  • Views 16k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The problem is , not wanting to just step away from Subaru...LOL Then at least you could have some real suspension. cheers
  • Scott in Bellingham
    Scott in Bellingham
    shortened the rear lid 8"
    Scott in Bellingham
    it drives   still got 100 things to do,
got the tranny mount  almost done , moved up the drivers side mount
1374779_1449852238573673_1213450421_n.jp
Edited by Scott in Bellingham
yes the EJ starter is shorter
very nice,for my T case setup that means I can mount the engine just a little further back.
looks like I may drive this Hog Tomorrow, today I tidied up the engine compartment, lengthened a heater hose, a gas hose, moved some wires around, moved the rad top forward 1/2", lengthened the steering knuckle,  mounted a 2000 Y pipe in, looks more like a U-pipe ,bought a rad hose, so looks like shifting linkage, driveline, rear track bar and its a driver, been just over a month so far, still got tons left to do , hope to hit the trails in a couple weeks
MO PICS
1185035_1452213578337539_1539176679_n.jp
1374122_1452214115004152_1261747379_n.jp
1379897_1452214075004156_1315373398_n.jp
stock 90 y pipe top, 2000 2.5 pipe on bottom, went with the 2000 as is shorter and Ill be mounting the exhaust
up high over the tranny crossmember and un against the body
1385159_1452214038337493_1105495926_n.jp
went to O Reilly's and found a hose that made  both top and lower  hose , they have literally  100s of hoses to choose from
1378534_1452213825004181_1347864764_n.jp
1375218_1452213718337525_1930437654_n.jp
1381440_1452213688337528_2000816145_n.jp
spray paint her florescent yellow on black wheels
how about black with florescent yellow wheels and lift blocks?
Edited by Uberoo
shorten the front now, it looks out of place with the non existant rear.
would like to, theres a rad and engine in the way, will be modifying bumper .
got the track bar all in, got the rear brakes hookup up and fixed, workin on the driveline now
Then at least you could have some real suspension. :)
cheers
cheers
cheers
I like the Subaru and hey its makin me a living, should hit the trail next weekend , still want to take a dualrange and add some real lower gears in the low range area, might take some welding and machine work with some added parts
How many degrees of motion do you have in that driveshaft center joint & what vehicle was the donor?
the front is stock 90 Subaru wagon from the car, rear u-joint and flange  is Toyota pickup, not sure motion, it does have forward/reverse movement, its like a cv joint
more gusset at the pan hard mount frame wise . Like . A LOT. Both sides.
I just keep wanting you to build something that will last.
Why won't you ? lol
Why won't you ? lol
Hmmm  I thought you might notice that
Ah, I get it...the center is a trunion joint.
Correct?
Correct?
It's a DOJ type CV.
Looks like a late 90's legacy driveline.  Some models have this type, others it's just a Ujoint.
My thought is that it won't have enough slip.  it's not a slip yoke.  When that axle starts going up and down that joint may not have enough travel.
Scott, look into Nissan and Izuzu drivelines.  Same input ends at the trans, and flange at the axle.  Get 2wd model one from nissan will have slip section in it.
Looks good.  How was it for road manners?  I'm guessing a front tube bumper is in the plans.
