October 22, 201312 yr I just installed a Subaru 2.5L out of a Legacy in my Baja bug. it seem that the rev limiter is set to 4200rpms is there any way to raise it up to around 6000 rpms ?
October 22, 201312 yr +1 speed senser needs imput try a inline speed senser mabee find one on 90s ford thats inline
October 22, 201312 yr Author I can do that. what pin on the computer is the VSS? does anyone have a copy of the pin out? Dalton
October 23, 201312 yr That rev limiter you are hitting is "limp mode". A lack of a VSS signal will put the car in limp mode.
October 23, 201312 yr There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch.
October 23, 201312 yr Author There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch. does anyone have the ECU pin out?
October 23, 201312 yr You can find the FSM for 99 here: http://www.main.experiencetherave.com/subaru_manual_scans/ Look in the wiring diagram section. ECU pinout should be in there. If not there look in OBD2 diagnostics under troubleshooting.
October 23, 201312 yr Nice rig....Does the radiator function well at its present location?? IMO, it looks a bit awkward where it is mounted. You would get better air flow if you swapped radiator and spare tire mounting locations. Something to think about.
October 23, 201312 yr Very nice job !!! a 90-92 wire harness from legacy will run that engine and needs no vss to run i use this harness becuse is non obd2 and has no limp mode makes better power to. You may want to think about that harness have had many problems trying to stand alone 95 and up harneses
October 23, 201312 yr Author Nice rig....Does the radiator function well at its present location?? IMO, it looks a bit awkward where it is mounted. You would get better air flow if you swapped radiator and spare tire mounting locations. Something to think about. the radiator seems to work fine. it does 80mph all day long. I wanted to keep the weight down low.
October 23, 201312 yr Author There's a pin that needs to be grounded so the ECU doesn't look for the auto trans. Also need to ground a pin to tell the ECU the manual trans is in gear, unless you used a Subaru trans, in which case you can just hook up the switch. does anyone know what pin needs to be grounded?
