Loyale 2.7 Turbo Posted November 22, 2013 Share Posted November 22, 2013 This is backwards That would be the dealer installed system. GL-10s had it factory and the pump is outboard of the Alt. Your GL had it added at the dealership. Very Kindly let me tell you, Gloyale: in my own humble opinion, you have the info Backwards. The Inboard A/C compressors are the Factory installed ones; the outboard A/C compressors are the Dealer installed ones. So, in order to stop the confusion, Trident and I found this: inboard A/C compressor = Factory A/C with two V Belts = Waterpump with 110 mm tall shaft. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 22, 2013 Share Posted November 22, 2013 But I'm open minded to any other Ideas / Info \ Documents that might proof otherwise... So, correct me if I'm wrong. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted November 22, 2013 Share Posted November 22, 2013 Dealer systems were hitachi, and are inboard. Factory systems were Panasonic/matsushita and are outboard with the exception of 85 early 86 were BOTH systems were inboard of the ALT. Just goin by the Factory Service manuals. Basically if it's not an XT or a GL-10 , you use the 110. If not then someone has swapped engines which happens all the time by now see cars with carb blocks with SPFI and MPFI turbo cars neutered w/ SPFI block etc. Subarus are like a Box of Chocolates.........that's all I've got to say about that 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 22, 2013 Share Posted November 22, 2013 (edited) Thank you for Clarifying! My Subaru "BumbleBeast" EA82 is year model 1985 Also, Trident's Subie is... ... my '86 GL ... ... 1986, So we both have Inboard Factory A/C. That explains it. Kind Regards. Edited November 22, 2013 by Loyale 2.7 Turbo Quote Link to comment Share on other sites More sharing options...
Trident Posted November 25, 2013 Share Posted November 25, 2013 (edited) One quick bit of info, I answered my own question concerning which Aisin pump was which. The WPF007 is the 105mm while the WPF003 is the 110mm. Comparison pic here: Edited November 25, 2013 by Trident 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 25, 2013 Share Posted November 25, 2013 Thank you for the Comparison Photo. That means that you've received the Wrong (Shorter = 105 mm) one, isn't it? Kind Regards. Quote Link to comment Share on other sites More sharing options...
Trident Posted November 25, 2013 Share Posted November 25, 2013 Yessir, it does. The Aisin pumps look to have the shaft size stamped on the pulley. You may be able to see the "105" stamped on this picture. Now if they would just list that in the part description... Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 25, 2013 Share Posted November 25, 2013 Again: Thanks for the Photo and Data. Sorry to read that you was given the wrong one... Might I ask you, if you could return it and obtain the right one instead? Kind Regards. Quote Link to comment Share on other sites More sharing options...
Rust Posted December 18, 2013 Share Posted December 18, 2013 going to be doing a water pump fix soon. I have an old gl-10 pump (shorter) I was going to use. Aside from possibly wearing out the belt quicker beacuse it's shorter, what other problems could arise. They both pump the same ammount of water, right? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 18, 2013 Share Posted December 18, 2013 The difference between the 105mm and 110mm pump is merely which pulley it uses. 110mm for studded pulley, 105mm for bolt-on pulley. that is all. Regardless of application, you can use either or water pumps as long as you have the associated pulley for that pump. mixing and matching pulley for one pump on the other will ruin the studs or the holes on the pulley, and will fall apart, or have a misaligned belt Quote Link to comment Share on other sites More sharing options...
Rust Posted December 19, 2013 Share Posted December 19, 2013 Any pics of the correct pulley for each pump, I never knew there was a differance. Quote Link to comment Share on other sites More sharing options...
