November 20, 201312 yr Your fuse might look good but pull it and check the end caps are not loose. My experience.
November 23, 201312 yr Author Thank You, Sometimes I fail to look for the easy fix. I passed this on to another Dude. Wayne
December 3, 201312 yr It could be the contact inside the switch. Remove the steering wheel and "lightly" emory cloth the contacts and bend to make a tight contact.
