January 30, 201412 yr Is there any real difference between the aftermarket axle manufacturers (e.g. EMPI, Cardone, FEQ) or is it all the same cheap Chinese crap? Thanks, --Damien
January 30, 201412 yr EMPI was touted, but there were a couple of reported failures. a search will show brands people like. i would favor responses from those that have done countless axles. "I've used these axles twice" anecdotal responses have no statistical validity and don't help the axle debacle. i'm sure you know this but getting used low mileage OEM Subaru axles and rebooting them is cheap, better quality boots than aftermarket, 100% repeatable, and they'll last the life of the vehicle if properly maintained. www.car-part.com
January 31, 201412 yr Is there any real difference between the aftermarket axle manufacturers (e.g. EMPI, Cardone, FEQ) or is it all the same cheap Chinese crap? Thanks, --Damien I would still go with EMPI of all the aftermarket options. The set I have in my Hatch have been going strong for approximately 3 years. I am probably going to swap them to the other respective sides soon, but they are not showing any indication of wear yet.
January 31, 201412 yr I have had great success with the DTA axles, they are all new materials, no reman. The only axles besides low mileage stockers that dont vibrate in drive while stopped in my auto cars are the DTA's. Isaac
January 31, 201412 yr EMPI was touted, but there were a couple of reported failures. a search will show brands people like. i would favor responses from those that have done countless axles. "I've used these axles twice" anecdotal responses have no statistical validity and don't help the axle debacle. No offense Gary, but you haven't used an aftermarket axle in how many years? I know you are all about OEM, but I'm not sure what debacle you are referring to.
January 31, 201412 yr Author well the new OEM ones cost a fortune and I'm afraid that with the remanufactured ones I'll get the same cheap Chinese one again...rebooted!
January 31, 201412 yr Author well $237 quoted...still a little stiff. I'd bite for those but I bet the axle stub is worn by now. Bump and grind! :-D
January 31, 201412 yr No one has mentioned them yet but MW Enterprises have done a great job in the past and used to be highly recommended here on the board for rebuilt axles.
January 31, 201412 yr Author Well...the lady on the phone gave a strong indication that Cardone was superior to FEQ... I hope she's right! Cheers, --Damien
January 31, 201412 yr Well...the lady on the phone gave a strong indication that Cardone was superior to FEQ... I hope she's right! Cheers, --Damien That sounds about right. I have used one set of FEQs. They lasted about a year. I also ordered a set for my Justy and they arrived without the circlips for the DOJs. The Cardones are kind of hit or miss. You might get one that lasts a long time or it might be clicky out of the box, but your chances are better with a new Cardone than FEQ.
January 31, 201412 yr Cardone failures are mentioned in the threads linked below. No offense Gary, but you haven't used an aftermarket axle in how many years? it would be months, not years. i work on dozens of vehicles so i use other peoples vehicles/parts too, it's not always ideal and i don't always get to choose. last new aftermarket set i installed vibrated on acceleration..classic inner DOJ aftermarket issue. I know you are all about OEM, used OEM axles. i use aftermarket parts all the time. but I'm not sure what debacle you are referring to. if you do enough axle work and see the vehicle long-ish term, it's all over the internet and any subaru forum, a simple search...like all these in like 30 seconds. i'm not reading them all but just as an illustration i'll copy and paste how common this is: http://www.subaruoutback.org/forums/66-problems-maintenance/23162-aftermarket-axle-print.html http://www.subaruoutback.org/forums/109-gen-3-2005-2009/42191-vibration-idle-not-due-axles.html http://www.subaruoutback.org/forums/66-problems-maintenance/37399-vibration-idle-after-replacing-front-axles-solved.html http://allwheeldriveauto.com/seattle-subaru-cv-boots-and-axle-problems-explained/ http://www.ultimatesubaru.org/forum/topic/120391-braking-vibration-after-replacing-cv-axles/ http://www.ultimatesubaru.org/forum/topic/130439-vibration-after-new-axle-04-legacy/ Well...the lady on the phone gave a strong indication that Cardone was superior to FEQ... I hope she's right! Cheers, --Damien Here's a USMB thread by Numbchux who does tons of Subaru work and he's seen Cardone failures. i recall him having Cardone failures so it was easy to look up. http://www.ultimatesubaru.org/forum/topic/114729-gsp-axle-rant/
January 31, 201412 yr Author Are they remanufactured or new ones? I would guess rebuilts may last substantially less long... The FEQs I had in there only lasted me about 18 months...
February 4, 201412 yr Author Well I just got those Cardone axles today. I inspected them and they are definitely brand-new and not remanufactured. It is a 'made in China' one but it does look very different from the FEQs I have installed now. Naturally, I won't know until they are installed and driven but I'll post more data as soon as I know for sure. So far...the lady wasn't lyin'. --Damien
February 28, 201412 yr Author Well I checked the inner race cup today after a few hundred miles of driving and it's kinda loose on the transmission stub. Maybe they are machined to be that way or maybe the splines are worn from the previous installation but either way looks like I'll have to live with it. Maybe this set will hold up better overall than the FEQs ...they definitely sound different.
March 1, 201412 yr A co-worker at my job has been in a position to visit Asia a coupla times - not mechanical related stuff, but he says there can be a big difference in quality among even ISO 9xxx certified companies. Some are certified by Germans, some by Chinese. And, ISO 9xxx really only secures a company's consistency, not their quality. If you turn out crap, ISO 9xxx helps make certain the crap is the same every time. did any ever find a way to get NTK , or whoever makes axles for Subaru, aftermarket? I seem to recall a S. African guy was gonna try that but, I don't recall any details. I wish I knew of some silver coating/paint that I could spray on the inner boot next to the exhaust. Somehow help to further shield it from heat. Edited March 1, 201412 yr by 1 Lucky Texan
March 1, 201412 yr I had very good success with EMPI. Girlfriend's Forester broke the original right front axle after 120k miles. Put an EMPI in and it has been great. Went right in, lined up perfectly. The Forester has since been handed down to her daughter who is in college and drives the car hard. Axle is still holding up great after almost 50k miles.
March 2, 201412 yr I have an EMPI in our H6 outback. I have no qualms about it failing, good value, very nice unit but it started causing vibration 'in gear when stopped' after a year. If her Forester is a 5 spd, she may never have an issue.
March 2, 201412 yr the transmission stubby shafts pop right out - just pull them if you ever want to entertain replacing them. a circlip holds them in place. if you suspect the shafts are the cause you can get another set. i think i probably have a known good set and i'm sure lots of others do as well. so far every case i can recall has been remedied with replacement axles, suggesting the stub shafts are fine, but i'm sure left in place long enough it would have to wear over time like water over a rock.
March 3, 201412 yr Just thought you guys might like to know that EMPI sold out that part of their company last year. I bought a set thinking I was getting the good old EMPI shaft, but the box it came in wasn't the same, and had a similar name, but not EMPI on it. Rock Auto was, and aparantly is still selling them as EMPI parts.
March 3, 201412 yr I knew I created a thread about this when it happened, but I thought I made it here. I guess that was wrong. Looks like I only did it on NASIOC. Here's a link with the info I found out when this went down. http://forums.nasioc.com/forums/showthread.php?t=2537233
March 4, 201412 yr Author the transmission stubby shafts pop right out - just pull them if you ever want to entertain replacing them. a circlip holds them in place. if you suspect the shafts are the cause you can get another set. i think i probably have a known good set and i'm sure lots of others do as well. so far every case i can recall has been remedied with replacement axles, suggesting the stub shafts are fine, but i'm sure left in place long enough it would have to wear over time like water over a rock. How can you replace those stubs without cracking the whole case open? I thought otherwise was impossible...
March 4, 201412 yr How can you replace those stubs without cracking the whole case open? I thought otherwise was impossible... for a manual the case does have to be split, automatics just pop right out and back in very easily. i was assuming you had an auto due to the discussion about axle stubs, where issues are usually with auto's. Edited March 4, 201412 yr by grossgary
March 4, 201412 yr I learned something AGAIN - I didn't know the MT stubs weren't just held in by circlips.
