February 3, 201412 yr i have a 1991 legacy 2.2 , just change the water pump timing belt and cam shaft and crank shaft seals, now trying to fill coolant system and can't get in to flow. any thiouights? or do i get a pressurize coolant system tool to fill it?
February 3, 201412 yr Did you change the thermostat with a genuine Subaru product? The thermostat has a 'jiggle valve' which is a small rod that hangs through a hole in the thermostat mounting flange. It has to be there and move freely. You did not indicate how much coolant that you have been able to add to your system. Did you try to add coolant through the upper radiator hose into the engine?
February 3, 201412 yr It takes about 2 gallons, a little less, Take a gallon of A/F and slowly fill the engine using the upper radiator hose and then put the hose on Fill the over flow tank Put the heater on high Start the engine and slowly fill the radiator When you think it's full, place your hand over the filler neck and burp the system. Squeeze the top hose until bubbles stop coming out Fill the system. Put the cap on and let it come up to temp and then cool. I will suck some coolant back in. Keep an eye on the tank until it stops going down.
February 3, 201412 yr +1 to what lmdew said. I personally fill the rad as well, then start the engine and top off the rad. I've always done this with the car pointed uphill, might not do anything, but I think it helps.
February 3, 201412 yr Most of the older cars have a bleeder cap on top of the radiator opposite the filler cap. Just a plastic screw with a large phillips head. If yours has it, remove it while filling the radiator until coolant flows out of it.
February 3, 201412 yr copied from another forum. how to fill and burp your cooling system.taglines: burpcoolingsystem; suphonfill; burpcoolantsiphon.compiled from previous posts:PART 1>1/ remove vent plug on radiator at top hose.2/ fill radiator at fill neck / cap SLOWLY. (slowly is key.)(i have written this a couple of times and it works great, for me. butit is so odd and extreme i really don't expect any one to follow it. sitthe jug of coolant on the passenger strut tower and use a long tube,about 1/4 inch diameter, to siphon the coolant in the rad. the process is so slow you will get bored, but slow works in this situation. )3/ when full install the vent plug and rad cap.4/ start the engine and run it up to full operating temp. then shut it down and wait for it to cool down.5/ open the rad and top it off. mine usually only takes a couple 3-4 oz.(most folks run the engine with the rad cap off to burpit. but i have found that when it burps it looses more coolant than itreally needs to so i just heat it up and then let it cool before iopen it. all you really want to do is circulate the coolant andeliminate any air bubbles. the siphon is so slow it really does not need much burping or topping off. this is different than most other fill and burp process. )good luck.PART 2>the last 2 times i have filled an empty cooling system on an ej25engine, i have used a very unusual method and have had NO problems andhave not had to burp.i put the gallon of coolant on top of the engine, either the passengerstrut tower or the air box near the firewall. i then use a smalldiameter tube (~5/16 inch, inside diameter) to siphonthe coolant out of the jug and into the rad. (it helps if the tube isclear so you can see the coolant as it gets close to your mouth.) afterthe jug is empty, i then start over with a half jug (2 qts.).this is a very slow process because of the size of the hose, but more sodue to the very small difference in height. the system fills veryslowly and has time to back fill the engine thru the top rad hose. imake sure the rad cap is at least level with or usually higher than therest of the rad. having the vent cap open helps too.the first time i did it i tried to burp it but i ended up wit h less coolant in the system than when the siphon had finished. so this last time i just let the siphon do its thing and then put the cap on. no problems.it works great, but it is really, really, slow. so i do it while i'mfinishing up the last little bits of whatever i'm working on.this is so slow that if you did it and then watched it you would give upand start pouring long before it got done. but it is a great time toopen a beer and admire your work.i doubt this is a good technique for a car that needs to be burped, but it works great for filling empty systems.HTH.PART 3>for 90s legacys, the small vent cap is the trick to filling correctly.coolant WILL NOT flow into the upper rad hose / engine block unless youhave the vent plug removed. and even then you have to fill it SLOWLY.once you have slowly added as much as it will take with the vent plugopen, close that, fill to the top of the rad and start the engine. whenthe t-stat opens the coolant will burpout of the rad and the level will drop. (in most cases it will drop, butif you filled it slow enough the system MAY be full.) top it off andput on the cap.(my solution to filling slowly is to siphonthe coolant out of the jug and into the rad. i use a 1/4''- 3/8''clear tube about 10 feet long that i bought years ago and i use it forall of my siphoning needs. it fills the rad so slowly you get bored.but you can rotate tires or change the oil while you wait. once it isfull, mine will not burp. it is full.)on a side note:if you used a non-subaru t-stat you are going to have trouble.they do not work and it will over heat. i know some of you do not wantto believe this but it is true. i was one of them for a long time.there are several parts on these engines that MUST be subaru. and hopefully you do not damage anything learning that.SOMETIMES, not very often, a ''high quality'' replacement part willwork, but ''cheap'' aftermarket parts are never a good solution forthese ''subaru only'' parts. they end up not working correctly and younot only have to redo the work (twice the labor) you have to buyanother, usually more expensive, part. buying parts twice is never costeffective, even if your labor is free. Edited February 3, 201412 yr by johnceggleston
February 4, 201412 yr Wow everything is so complicated, whne it is really easy. First off you need a chicken that was born on the night of a new moon when capricon is setting and venus is rising ... or With the system drained and on level ground. Start car. SLOWLY add coolant (50/50 premix no tap water) until the radiator is full Monitor the temp gauge and wait for some overflow from the radiator neck. This will indicate the T-stat has opened. The coolant will go down and drop, now SLOWLY add more coolant till full. Put cap on radiator. Fill overflow to hot line. Drive car around block, shut off, allow to cool. Repeat after car cools off. That's it. This works on almost every car and has since the dawn of water cooled time.
February 10, 201412 yr Author thank you all for the help with this air pocket. i fixed it by getting a rad. vacuum tool and pulled it down to -30 lbs pressure and then filled it with coolant and water in one bucket and dropping a hose to the bottom and opened the vavle , and it was full after a min or two. runs great and no over heating , accept at the heater as it should be. again thank you all nice to see there are good poeple willing to help
