GL won't start after girlfriend added too much oil...
If you know that the engine rotates, check the oil pressure. If you have a broken timing belt on the passenger side, the oil pump does not rotate. Zero oil pressure on the gauge and the engine cranks over with little resistance.
Oil pump is driven by DRIVERS side belt. (For LHD)  Same as the disty.
Smart cause you don't want the engine running with the oil pump not spinning......and they can run with no passenger side belt.
This is a broken timing belt.  Can tell by the sound
  • Replies 56
  • Views 11.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Maybe it sucked some up in the PCV. oil capacity should be about 4.5 qts with filter.   Sp the engine is hydro locked, or just won't start? maybe the cylinders are full of oil. correct the oil level
  • Malcontent
    Malcontent
    She pointed to the oil cap.
  • Silas Cruse
    Silas Cruse
    here is how i fix my 1991 ea82 a few years ago:   Turns out that the single fuel injector was STUCK and i used a large handled screw driver as a soft mallet to free it, no joke. soft TAP, soft TAP,
Posted Images
I gotta agree with Gloyale, sounds alot like a broken timing belt.
Could too much oil put extra tension while starting and snapped the belt? New to the Suby so not sure if that's possible or not...but it sounds reasonable ? :)
Edited by Discombobulated
No.
No.
Well......I don't know you could say for sure.........but i feel like it could.....I feel like i've seen this scenario before.
  • 1 month later...
Interested to see where this goes.
I am thinking timing belt as well.... warming some popcorn to wait for malcontent to let us know
This may sound too obvious, but it's caught out more than a few: does it have fuel?
I think the original carbs have a sight glass in the float bowl. Our you can pull off the air filter, look down the throat of the carb and pull on the throttle linkage. You should see some fuel getting squirted into the throat of the carb.
