April 5, 201412 yr Just bought a legacy that doesn't run, the guy I bought it from said the timing belt broke but just confirmed that it is still in tact. When I turn the key all I hear is a click
April 5, 201412 yr The click could be simply because of worn copper contacts in the starter's solenoid, a fairly common problem on older Subarus. It's a cheap and fairly easy fix. If the timing belt is okay check to make sure the timing marks on the cams still line up properly. Good luck.
April 5, 201412 yr can you rotate the engine manually? (21mm socket on the crank bolt, turn clockwise) if yes, then I would agree with Olnick - bad starter contacts and/or bad connections. also make sure battery is fully charged...
April 5, 201412 yr can you rotate the engine manually? (21mm socket on the crank bolt, turn clockwise) if yes, then I would agree with Olnick - bad starter contacts and/or bad connections. also make sure battery is fully charged... 22mm socket. Weak ig. switch. Add a relay to starting system......or pushbtton.......or both.
April 5, 201412 yr 22mm socket. Weak ig. switch. Add a relay to starting system......or pushbtton.......or both. oops - you're right...22mm (hadnt had enough coffee yet! LOL)
April 5, 201412 yr Author Also I'm only wanting to get this car running so that I know the engine is good so I can then rip it out and cram it into my brat, is there a way to bypass the starter just to get the engine running?
April 5, 201412 yr Also I'm only wanting to get this car running so that I know the engine is good so I can then rip it out and cram it into my brat, is there a way to bypass the starter just to get the engine running? If stick shift, push to 5 mph, then pop the clutch to start, without using the stater. If automatic tranny, then can only start with a starter.
April 5, 201412 yr you can jump a wire from thebattery to the small tab on the starter to work around the ign switch and circuitry.
