April 15, 201412 yr cake. are you positive it's the A/C compressor? they rarely fail but of course at that age/mileage anything is possible. it's usually the orings at the a/c compressor that leak refrigerant. 1. replace compressor with a used one, ask in the classified section here or: www.car-part.com 2. replace two orings on compressor, just match them up at any auto parts stores (cheap) 3. replace schrader valves in high and low port (cheap) - standard, again match them up an an auto parts store 4. add two cans of refrigerant - 21-24 ounces I think the system takes - no need to vacuum system. A/C will likely last the life of the car. Other than the hoses that bolt to the compressor there's no other parts that fail commonly. Subaru A/C systems are very robust and don't require much maintenance/repair if they're approached properly.
April 15, 201412 yr Author The pressure is fine and when the clutch tries to engage it acts like it is siezed and makes a loud moaning sound and doesn't put out cold air. Cycling the A/C switch will bring on cold A/C until it siezes (or is restricted from turning). Prior to adding refrigerant the A/C would repeatedly cycle on and off, which I think brought on the clutch failure.
April 16, 201412 yr Doesn't sound like the clutch to me, sounds like the whole compressor is shot. After it stops working, turn the car off and see if you can easily turn the inside part of the compressor clutch by hand. It should move pretty smoothly.
April 16, 201412 yr copy - you're sure pressures are good? if they're too low or too high the compressor will shut down. one or two of the lower bolts are really annoying to get to and i think the way it works is you can loosen them but don't have to remove them entirely for the compressor to come out. take a look at it closely it's foggy but i think you can unbolt a lower mount and have that come out with the compressor or something. i never bother installing one of the lower bolts when reinstalling, it's complete overkill to have all those huge bolts on such a low key part. the engine is bolted in place with 2 nuts and one bolt - 3 fasteners. and the A/C compressor gets 4 14mm hold downs, that's hysterical. Edited April 16, 201412 yr by grossgary
April 18, 201412 yr Author The noise is coming from the receiver dryer. What parts are in there to make noise?
April 18, 201412 yr The noise is coming from the receiver dryer. What parts are in there to make noise? probably fluid resonating, vibrating, or otherwise flowing through/around some passage. they don't make noises unless it's some weird ball outlier, they're just a metal tube going through a can with desiccant inside. Subaru A/C systems are extremely robust - failure of any component is almost unheard of, though compressors and clutches can fail, but it's pretty rare and it seems you've ruled those out. so far all symptoms point to having too much refrigerant in the system. have you checked the pressure - what was it?
April 18, 201412 yr The noise is coming from the receiver dryer. What parts are in there to make noise?is it a hooting kind of noise, heard after the compressor stops? that's from an over-charged condition.
