Seeking info for 84 Brat turbo
I've got an 84 EA-81 1.8L MPFI turbo engine. My manual shows a dropping resistor that the injectors connect to. I need: either a service-able dropping resistor, or the resistance (and wattage) so I can put something together to run the injectors without frying them. Thanks, Bob
You need a new manual not a resistor.
Your car does not use one.
  • 8 months later...
To set the record straight: My injectors did require resistors. 10 ohms 25 watts does the job (don't know if this is factory specs but it works fine in my application).
I like it when someone is wrong, and gets corrected :)
It is good to know you got it sorted. I did not think the dropping resistors came in until the EA82 went four plug ecu !
The dropping resistor you used went on the constant positive power supply side, and switched the earth side vua the ECU ??
Good catch! I am building 2 of these engines (EA81T) right now and at least 1 will use the stock harness and ECU. I didn't even know this critical detail. Thank you.
How did you determine that?
The factory does not use dropping resistors on the EA-81T.
What IS your application exactly?
Edited by naru
Then you will like this.
You still don`t.
I have rebuilt my EA-81T engine wiring harness in recent months.I`m driving it now.
Ok Gang, Here's what's going on.
There are 2 types of injectors (any car) high impedance (Hi Z) or low impedance (Lo Z). Hi Z injectors will measure about 12 to 16 ohms, Lo Z injectors measure about 2.5 ohms or less. Measure this with your ohm meter. Hi Z injectors don't need resistors, Lo Z need resistors or a circuit called peak and hold (full current to open injector, then less current to hold it open).
My injectors are Lo Z (2.4 ohms) and needed 10 ohms to limit the current. The resistors go on the power (plus) side and the ECU switches the ground. If you fire more than one injector at a time, you need one resistor for each of the injectors that fire together. I believe the EA-81T was bank fire and fired the injectors in pairs. I'm running sequential fire (each injector separate).
I don't know what the factory was doing at any particular year or model, but my injectors are Lo Z. I bought the engine used (it was complete) but I never saw the car it came from (engine might have been pulled from a car in Japan). I never saw the wiring harness or computer and couldn't locate a computer for the engine. I built a computer from a kit (MegaSquirt) and I drive this engine daily (it's in a 65 Fiat). i'm still working on getting the best tune for the engine.
Cool,How about a photo of this radical Fiat.
850?
Edited by naru
1100 D Station Wagon I posted a description and some photos at "Member's Rides". Post title: Subwat
