trouble starting...
hey there. my wagon is tough to start...most of the time...I did a search, but I need more opinions for my situation. here goes...
86 turbo wagon
the car will crank and crank. I smell gas so I wait in case I flooded it. try again...cranking, cranking, no fire. wild idea, I pulled the ig. coil fuse to hopefully work some of the fuel out and cranked it for a minute, then I put the fuse back in and then it starts (barely, with foot on the gas so it stays alive) this is how I start it every time now. here is the weird thing. It runs fine once it starts. no hesitation. no stalling. the plugs are new. wires are ok. Im thinking coil or amp or cap and rotor...but why would it run fine once its started?
Maybe its low fuel pressure. Due to a small leak? I don't normally smell gas. Perhaps you could check the pressure regulator, and fuel filter/pump for correct fuel pressure.
