June 12, 201411 yr i cant decide if i want to weld the rear diff on my 78 subaru brat. it has a 4 inch lift, and i run 27-29 inch tires on it. i primarily use it off-road, but it does see occasional highway driving and around town. if i weld the rear diff, i know it will help a lot off-road, but im afraid that when i drive in on pavement i will break axles or the diff itself. i know some people weld the diff, then remove an axle for street driving... but that sounds like a pain to do all the time. what are your experiences with welded diffs? should i do it?
June 12, 201411 yr Weld it,Over inflate your rear tires for street driving,drive it fast around turns so there is less force on each axle,finally when turning from a stop turn as wide as you can to again minimize the stress on rear axles.I will say though that actually blowing a rear axle or the diff on the street is rare unless you pull the front axles for RWD shenanigans... However,it is not advised to weld it with a 110 welder,unless you can heat the spiders to a dull red with a torch to get more penetration. also when your driving on a slow curvy paved road (sub 35 MPH) it can help if you intentionally drop one of the rear tires into the dirt. Edited June 12, 201411 yr by Uberoo
June 12, 201411 yr Author i appreciate the input so its not that big of a deal on pavement around town? i have access to a 220 mig welder, that should do the trick right? also, im going to be running some deep tread tires, does that make a difference?
June 12, 201411 yr other than tire noise its not a problem because the rear axle is just dragged through corners without power being sent to it.
June 14, 201411 yr I picked up a spare rear diff to weld so if I screwed up and it breaks, I could plug in the original. Edited June 16, 201411 yr by ironworkerboomer
July 9, 201411 yr i'd like to do that if i can find one on the cheap I have a 3.9 diff laying around in Missouri... I could have a friend ship it if you're interested
July 9, 201411 yr Author im actually thinking about ditching the brat project.. but i will let you know if i change my mind, thanks
