TheSubaruJunkie Posted July 5, 2014 Share Posted July 5, 2014 So i picked up this wagon and the 5spd has a rediculous amount of slop in it. Today i pulled the shifter boot expecting to see a couple mangled shifter bushings, only to find everything in real good condition. Is the slop going to be internal or is there something else I can check? Thanks -Brian Quote Link to comment Share on other sites More sharing options...
lvsarge Posted July 5, 2014 Share Posted July 5, 2014 I don't own a legacy, but on my 06 impreza a lion's share of the slop was remedied when i changed the front and rear shifter linkage bushings to poly under the car -- you wouldn't be able to see them from the top, I do not think. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 5, 2014 Share Posted July 5, 2014 The slop comes from the u-joint kinda thing on the transmission end of the linkage. Scoobymods used to have a thread with a write-up on replacing the joint on newer Impreza. The legacy joint is similar but on the older ones it has bolts instead of rivets so you could replace just the bushings for about $3 each. Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 5, 2014 Share Posted July 5, 2014 What Fairtax said--it's definitely the bushings in the "boss joint" (the u-joint thingy) that connects the shifter rod to the tranny input. Been a lot of discussion of the job over the years. Try a "search"--go to advanced search, enter shifter bushings and choose New Gen Forum. Here's something I wrote up in '07: http://www.ultimatesubaru.org/forum/topic/73273-shifter-bushing-happiness/?hl=%2Bshifter+%2Bbushings Good luck! Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2014 Author Share Posted July 6, 2014 Thanks everybody. I did a search and the only real guide I found was yours Olnick. In yours, you mention to Subyluvr his guide, but I could not find his. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 10, 2014 Author Share Posted July 10, 2014 I still cant find any guide written by Subyluvr. Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 11, 2014 Share Posted July 11, 2014 Finally tracked down some info! It's all bits-and-pieces from years ago but I hope it helps you. Back when I did mine, one of my best resources was the exploded view drawing in the Haynes Manual, page 7A-2. Here's "subylovr's" write-up (he changed his user name to "DerFahrer")--but pictures are gone: http://www.ultimatesubaru.org/forum/topic/60847-shifter-bushing-replacement/?hl=%2Bshifter+%2Bbushings&do=findComment&comment=493970 Another write-up (but the photos don't seem to be accessible): http://www.ultimatesubaru.org/forum/topic/37332-legacy-mt-shift-linkage-photos-here/ Here are some good pix of the parts from Nasioc: http://forums.nasioc.com/forums/showthread.php?t=742063 Ask any questions you have . . . maybe more specifics will come back to me! And good luck--it's really worth the effort if you can bear with the pain! Quote Link to comment Share on other sites More sharing options...
gdudik Posted July 11, 2014 Share Posted July 11, 2014 Slightly OT, but I'm going to ask a small favor. In Jan 2013, on my wedding night, I had a 95 Legacy wagon stolen from the hotel room parking lot. It also had a 5 speed with a lot of slop in it. The vehicle was never recovered. I know it's very unlikely that it's the same car, but I'm from the Portland, OR area, and I was wondering if it might have made it down to where you are. If you just purchased it, did you do any kind of carfax or something like that to see if the VIN came up stolen? Mine was dark red. I proposed to my wife on the beach in that car. I still hold out faint hope it will come back. Thank you! --Graham Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 12, 2014 Author Share Posted July 12, 2014 Finally tracked down some info! It's all bits-and-pieces from years ago but I hope it helps you. Back when I did mine, one of my best resources was the exploded view drawing in the Haynes Manual, page 7A-2. Here are some good pix of the parts from Nasioc: http://forums.nasioc.com/forums/showthread.php?t=742063 Ask any questions you have . . . maybe more specifics will come back to me! And good luck--it's really worth the effort if you can bear with the pain! Thanks a million!! That nasioc thread is exactly what I needed. Ive been reading that there are several different changes made to this part across model years, so I am hoping a guide like this will help me track down the correct parts. I forgot SubyLuvr changed his name... that explains why nothing came up. gdudik, i did not run a carfax or anything, but my car is white, has no ABS and rear drum brakes but power windows... and a salvage title. Don't think its going to end up being your stolen sube. Sorry to hear about your misfortune. Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 12, 2014 Share Posted July 12, 2014 You're welcome. I was tickled I could find all that stuff again too! One bright spot--my car is also a '95 Legacy and it has the simplest boss joint. It's held together with nuts & bolts, so access to the bushings is pretty simple. Again, good luck! Keep us informed on your progress. Quote Link to comment Share on other sites More sharing options...
gdudik Posted July 17, 2014 Share Posted July 17, 2014 Thanks a million!! That nasioc thread is exactly what I needed. Ive been reading that there are several different changes made to this part across model years, so I am hoping a guide like this will help me track down the correct parts. I forgot SubyLuvr changed his name... that explains why nothing came up. gdudik, i did not run a carfax or anything, but my car is white, has no ABS and rear drum brakes but power windows... and a salvage title. Don't think its going to end up being your stolen sube. Sorry to hear about your misfortune. Yup not mine. I just liked that car! Thanks anyway. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 19, 2014 Author Share Posted July 19, 2014 So I was speaking to a friend of mine who has done this before, and he said on his trans he just removed the bolt holding the u-Joint to the transmission side... instead of removing the double spring pin & "Y" piece. I might try this method as it sounds a lot easier than removing 2 roll pins. I also found this replacement joint: http://turninconcepts.com/driveline/tic-5mt-linkage-update.html its a little out of my budget at the moment, and im not even sure it will work. Im sure i have a centering spring on mine, i will know more when I get under the car and take it out. Im sure all I need are new bushings, and don't feel like emptying my wallet... besides, im still not sure exactly which bushings will work in my '95, i have not found any definitive information on the differences between models and years. But im going to continue searching. Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 19, 2014 Share Posted July 19, 2014 That's exciting that TurnInConcepts has bushings for the "boss joint." They didn't offer them back when I did mine. And no one has ever been happy with the longevity of the Subaru OEM bushings! No idea why their boss joint unit is only for "springless" models. You might try contacting them and asking. I dealt with Clint, one of the owners of TiC and a Subaru guy himself--really nice guy. If they sell just the bushings I think it'd be a good investment. As for removing just the bolt holding the joint--good luck! As I remember there's no way to get a wrench up in there. I wish you success and if you accomplish it, by all means let us know how! Good luck! Quote Link to comment Share on other sites More sharing options...
