Marck Posted May 10, 2004 Share Posted May 10, 2004 How do you remove the lower right corner joint on the windshield (that black plastic thing that borders the windshield)? I need to remove it so that I can take care of a small patch of bad rust. I tried to pull it, but I am worried about breaking it. Is it just glued in? If I end up breaking it, is it expensive to replace? BTW, this is for my 87 coupe. Link to comment Share on other sites More sharing options...
soobme Posted May 11, 2004 Share Posted May 11, 2004 I don't know about re-placing it, but I do know that it's glued in with the pollyurithane that holds the windsheild in place. Mine came out real eazy, but every car is diferent. Link to comment Share on other sites More sharing options...
northguy Posted May 11, 2004 Share Posted May 11, 2004 You can always cut it off with a serrated knife and reapply it with urethane glue - just surface apply it. Link to comment Share on other sites More sharing options...
Marck Posted May 11, 2004 Author Share Posted May 11, 2004 So if I remove it, will the windshield leak? Link to comment Share on other sites More sharing options...
northguy Posted May 11, 2004 Share Posted May 11, 2004 What, I believe, you are talking about is the corner trim on your windshield. It "connects" the side and bottom trim pieces together. It is merely a "L" shaped piece of plastic with a little leg on the back side that clips around the shield and sits in the urethane. If you remove it and it didn't leak before, it shouldn't leak after. To ensure it doesn't, put more urethane in before you replace it. Glue it down well. Link to comment Share on other sites More sharing options...
