July 19, 201411 yr I've got a line on a 5spd dual range transmission from a GL to swap into my my 5 speed loyale. The new tranny doesn't have a gear shifter bu does have the dual range shifter. Could I use the push button shifter on the dual range tranny? Obviously the push button doesn't work.
July 20, 201411 yr Author Sorry, I'm not sure I understand. The new tranny has the hi lo shifter but no 5 speed gear shifter. Will my current gear shifter that has the push button on it work with the new tranny and the hi lo shifter? Sorry I don't know the proper terms. I'm jut concerned about the stick shift not the dual range levers.
July 20, 201411 yr If I understand what you are saying, yes I believe the "business ends" of both sticks are the same. It might not be pretty but it should at least function.
July 20, 201411 yr Author Exactly what I mean. Thanks. How do you mean not pretty? I assume you could slip the pb stick into the console of the dual range and it would look fine. Or do you mean more than aesthetically pretty?
July 20, 201411 yr I just meant that you might have to get creative with the shifter boot or the surrounding plastic. Even so you should be able to make it look sweet. Lots of us have extra parts too. Give a holler if you need the correct shifter and I'm sure someone will even have the proper color. This place is AWESOME like that.
July 4, 20178 yr The EA82 dual range lever is bolted to the rear of teh 5-spd shfter plate. Uses the same two holes that hold the rear mounting/isolator. One could install the entire D/R shifter to a single range shifter. Literally nothing is different other than the stick has a button. (shift knob held by roll pin, rather than threads) Parts needed: D/R lever/pivoting assembly. Rubber floor boot from EA82 D/R Shaft to connect D/R lever to the D/R input of trans.
