Subarocket Posted July 19, 2014 Share Posted July 19, 2014 I've got a line on a 5spd dual range transmission from a GL to swap into my my 5 speed loyale. The new tranny doesn't have a gear shifter bu does have the dual range shifter. Could I use the push button shifter on the dual range tranny? Obviously the push button doesn't work. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 20, 2014 Share Posted July 20, 2014 yes for the 5speed just wont have the hi-low lever Quote Link to comment Share on other sites More sharing options...
Subarocket Posted July 20, 2014 Author Share Posted July 20, 2014 Sorry, I'm not sure I understand. The new tranny has the hi lo shifter but no 5 speed gear shifter. Will my current gear shifter that has the push button on it work with the new tranny and the hi lo shifter? Sorry I don't know the proper terms. I'm jut concerned about the stick shift not the dual range levers. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted July 20, 2014 Share Posted July 20, 2014 If I understand what you are saying, yes I believe the "business ends" of both sticks are the same. It might not be pretty but it should at least function. Quote Link to comment Share on other sites More sharing options...
Subarocket Posted July 20, 2014 Author Share Posted July 20, 2014 Exactly what I mean. Thanks. How do you mean not pretty? I assume you could slip the pb stick into the console of the dual range and it would look fine. Or do you mean more than aesthetically pretty? Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted July 20, 2014 Share Posted July 20, 2014 I just meant that you might have to get creative with the shifter boot or the surrounding plastic. Even so you should be able to make it look sweet. Lots of us have extra parts too. Give a holler if you need the correct shifter and I'm sure someone will even have the proper color. This place is AWESOME like that. Quote Link to comment Share on other sites More sharing options...
Subarocket Posted July 20, 2014 Author Share Posted July 20, 2014 Thanks! Quote Link to comment Share on other sites More sharing options...
jsyme Posted July 3, 2017 Share Posted July 3, 2017 How did this go? were you successful? I'm looking at the same project. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted July 4, 2017 Share Posted July 4, 2017 The EA82 dual range lever is bolted to the rear of teh 5-spd shfter plate. Uses the same two holes that hold the rear mounting/isolator. One could install the entire D/R shifter to a single range shifter. Literally nothing is different other than the stick has a button. (shift knob held by roll pin, rather than threads) Parts needed: D/R lever/pivoting assembly. Rubber floor boot from EA82 D/R Shaft to connect D/R lever to the D/R input of trans. 1 Quote Link to comment Share on other sites More sharing options...
