self etching or epoxy primer?
Gonna prime my 83 brat soon. The plan so far....
1) sand it and repair rust  (already done)
2) acetone it clean, possibly isopropyl alcohol after that
3) prime it!
4) body filler appropriate places
5) more primer
I was just gonna use the epoxy primers they have now a days cause they are pretty great
but then i was looking at my brat and sanding the rust off and thinking it would be great to have the acidic part of self etching primer
to get any of the surface rust that might be hiding in gaps or wherever (so hard to get it all)
can I body fill over the self etch?
or should i just stick to the epoxy?
I googled it of course but there is alot of different opinions out there thought i'd ask you knowledgeable folks
If you're painting bare metal I'd recommend self-etching as it'll stick to the metal better due to the chemical reaction, but if you're priming over existing paint epoxy should be fine. Since you've sanded it back I'd go with the self-etching.
One thing though, it's not a rust-converting paint - so if you spray t over rust it won't stop the rust. It's just designed to etch new, clean metal.
Cheers.
^Exactly what KiwiGL said.
Cut out all the rust first and use etching primer on any bare shinny metal.
Look for a primer with zinc chromate, will be yellow to greenish color.
No body filler over self etching primer. It doesn't adhere properly and will never feather edge.
