Sealing cam carriers to heads
DaveT
Last night, I assembled the cam carriers to the heads on an EA82 engine.  I used the Permatex anaerobic gasket maker and surface prep activator.  The exposed stuff that oosed out of the joint when I tightened the bolts has still not set at all.
Is this normal?  OR What went wrong?
Oh, good.  Thank you!  I really didn't want to have to be delayed and re do it.
The engine I reassembled a month ago, I had more time with, and got fancy.  I used my dremel to widen the groove enough to fit o-ring cord into it.  It sealed up nicely!
I have always used the factory re-inforced o'rings with the 518, am I missing a new trick?
