Intake valve control solenoid
Just got code P0028 after check engine light came on. "Intake valve control solenoid circuit." Is it easy to get to this circuit? Want to check for intermittent or dirty electrical connection and as this check engine indicator sometimes goes away. Can someone point me to this solenoid too? thanks.
Follow-up info: Car is a basic Legacy, 2007, sedan, automatic, 53K miles, runs great.
On that code, I'd be tempted to clear it and see if/how quickly it returns.
I've had 2 instances of 'spurious' codes set on one car - and one instance on another. On one of those cars, a dead cell in the aging battery 'seemed' to be the cause. Might be electrical gremlins - old battery, poor ground connections, loose harness connectors.....
Edited by 1 Lucky Texan
