Bleeding my brakes.
Howdy,
I've looked but I can't find a straight answer. I just replaced my left rear wheel cylinder and line. Do I need to bleed all 4 brakes or just the front right and rear left because they're on the same circuit?
Thanks.
Edited by rewsiffer
The search on the site can difficult at times. Please search Google, You will find your answer....
Edit:I found it right away...just saying
Edited by superpoo93
Bleeding the 2 on the circuit should do it.  If it doesn't , bleed the other 2.  Probably wouldn't hurt to replace all the fluid anyway, unless you did so recently.
As it stands, the brakes work but are way spongier than before. I can brake hard but I can't lock the wheels. I will try all 4 wheels.
put clutch in when bleeding an old soob......because hillholder
