January 6, 201511 yr I have a 02 outback with just over 130000 miles and the temperature gauge is reading hot but the engine is cool. The heater is fine no over heating smells and when I idle the temp drops to normal. It is in the low 30s and forecasted to get colder. I think it is the thermostat but not sure.
January 6, 201511 yr Do you mean the radiator is cool or the engine? Get yourself a code reader to see what the actual temp is. After that It can be a stuck thermostat, bad cap, clogged radiator.
January 6, 201511 yr Coolant level is good? Thermostat would be next on my list. Subaru OE or an OE equivalent type only. The cheapo stats don't work right.
January 7, 201511 yr might be a good idea to check the charging voltage. Edited January 7, 201511 yr by 1 Lucky Texan
