Anyone in Rogue Valley have a mig torch?
I have a problem with both of my front seats, the outside rear spot where the seats bolts to the frame(of the car) is broken. I think the body needs to be built up and solidified.
Also how much is it in materials to scratchbuild a new Y-pipe (1.75 tubing) minus the cat? and do I need to leave in the O2 sensor?
Yeah, Soobme has a torch, he gets home early in morning, so he'll prolly reply then.
As for the Pipe, if you go around to some of the muffler shops they will sell you a 5 foot stick for like 10 bucks, and then have them put two 180 bends in each end of it, they will charge for the bends also, vary's per shop. So you can figure like 15-30 for the materials to build it.
Not sure if we've met before or not, I usually sent out a pm to new people to the board from the Rogue Valley. You should check out the meet'n'greet section, the Rogue Roo's got a trip comin up next weekend.
Great info for the pipes, so I take it its then just a matter of cutting off the 3 adapters (two head and one exaust) and welding those to the new pipes and then welding it together in place?
I think I might be able to afford this. How much would the torch usage cost from you guys?
No I never got any meet or greats other than from matt and mike (But I do know those two).
I cant make any trips for two reasons. I work saturdays and my tranny is on the verge of death, works around town but if you heard it youd know it wont hold up for much heavy duty stress. It has been pulling a 3200+ lb car around for 22 years and 209k miles.
Alex
No doubt, my brat wieghs in about 3300 and it's got a 6cylinder, t-case, 3/16" wall 2x2" tube frame, 2"x1/4" tube rollbar, and a bunch of recovery gear!!!
I have no clue why it weighs so much. You should know though I have about 100-200 lbs of tools in my trunk and the normal 50 lbs of crap in the back seat, plus I have added heavier wheels, and then of course im 220 lbs. So all that will bring me up to about 3600-3700 lbs total.
Here is my Data plate
http://id.mind.net/~alexc/Subaru6.jpg
Its a 4 door sedan, so I have no idea why is heavier than the wagons etc?
That's gross vehicle wieght *including* all cargo. You must subtract the cargo capacity to get the vehicle dry wieght - 3220 - 800 = 2420 lbs :)
Donno, Sounds like the math works except I weighed it on the scales one day, got 3100. I dont know how accurate ODOT scales are, I was figuring they were under weighing me.
