Sign In
Forgot your password?
Finally closure
May 21, 201510 yr
If it were me I would buy the full kit and install on the 01 outback. Then take the old belt and try it on the forester.
June 2, 201510 yr
Belt marks are often wrong. Does the belt kit say the total tooth count for that belt? There are different belts for the SOHC engines and the way to identify them is by total tooth count.
June 6, 201510 yr
Your right side (passenger) sprocket doesn't look like its lined up with the seam on the head properly. Line up the notch on the sprocket with the seam between the camshaft retainer plate and the main
Is ted an architect?
No,just seems like a Ted...
Plus he Totally Escaped Death!
