Driveshaft extension
Just curious for those of you who have had to get a drive shaft extended from doing a trans conversion, how much did it cost you? In NC when I had this done it was around $100-$150, but now that I am in SoCal its about $100 more. Is that about right for this area?
  • 2 weeks later...
Shortening driveshafts is cheap, but lengthening them is expensive because it requires all new longer tube,plus the labor of cutting and welding both ends.
I ended up getting a total custom unit with Spicer 1410 U joints. Cost about $430, but they say it will never break. I also have the option to service the u joints now.
Yea, and when I had it done, they had to mill the flanges down to accept standard diameter tube (still cheaper than getting metric tube). It was $150ish 8 years ago or so.
  • 5 weeks later...
  • 2 months later...
My 3 inch Lift + 5 speed required a longer driveshaft. I used a 94 legacy auto front  shaft and Loyale back shaft. Gave me around 55 inches and I custom made a center bearing bracket.Works great and very little angles
