June 11, 201510 yr I'm putting a 5 sp into an EA81 body. I'll be doing a 2" lift. I was thinking of just adding the 2" into the customised crossmember instead of putting spacer blocks in. The issue may be, that the radius rods will be at more angle. Could this work? Has anyone tried it before? Too much wear on the rubber joints?
June 11, 201510 yr Yes you can make a custom crossmember with the lift incorperated but You need to put 2 inch blocks under the radius plates. as well as all the other normal lift spots otherwise you will need to stock up on CV shafts. TOONGA
June 12, 201510 yr Author Thanks Scott, so 1 inch difference tops? Toonga, why would I make the crossmember drop the gearbox and than drop the plates which hold the radius rods and gearbox crossmember as well? Yes Uberoo, with a conventional lift that is the case, but I'm thinking of just dropping the gearbox with the crossmember which will need to be modified anyhow, leaving the plates that it mounts to firmly against the body. My concern is the angle of the radius rod rubbers and the extra twist it will cause on the control arm rubbers.
