July 14, 201510 yr Can a front wheel drive tranny be exchanged for a 4 wheel drive tranny in a 1987 subaru gl and bolt up perfectly
July 14, 201510 yr Id does bolt up perfectly but you will have to swap all the associated rear suspension, driveshaft, differential. You will have to fashion a mount for the carrier bearing. You will have to drill and use thru bolts for the rear diff hanger, although the holes are stamped in the body for yoou to drill out.
July 14, 201510 yr Look who's back! Id does bolt up perfectly but you will have to swap all the associated rear suspension, driveshaft, differential. You will have to fashion a mount for the carrier bearing. You will have to drill and use thru bolts for the rear diff hanger, although the holes are stamped in the body for yoou to drill out.
