August 25, 201510 yr I have a 1999 Legacy GT with the 2.5L EJ25D (dohc, phase 1) and I want to swap the heads. Now I know that I'll need new 2.2L heads with dual port so I don't need to change my exhaust, and I've read that you need a new timing belt. (Donor car will likely be 1995 Legacy 2.2L) Now here are the issues: - Do I need to use the 2.2 head cam sprockets or can I use the ones from the 2.5?- Besides the previous question, do I need anything else other than the 2.2 belt for the timing system?- The bolt pattern for the 2.5 manifold I have has bolts in a straight line, however the 2.2 heads I've seen (1995 and older) have diagonal bolts.- Can I use the 2.5l head bolts? I have a new set which I will use. 14mm 12 point.- Is the bolt pattern the same? My current one has 6 bolts, 3 on top behind the top cam, and 3 down low behind the bottom cam.- If the donor engine (2.2L) didn't have HG issues should I still get the heads planed by a machine shop?- Should I get new valves seats/guides/valves/springs or is that overdoing it?Pics are here (2.5l head, block and manifold): http://imgur.com/a/ExhsZ
August 25, 201510 yr HI and Welcome, 1. Use the sprockets that match the head....they may work but I'm not sure. 2. You'll have to compress the tensioner - hopefully you have the FSM (factory service manual) for instructions - do it wrong and it'll ruin it. 3. SOHC Intake Manifold must be used - NOT interchangeable between SOHC and DOHC. 4. No...use head bolts that match head...I 'think' they're too short for the SOHC. 5. Yes...ALL EJ-series share the same pattern. 6. Yes....all heads should be resurfaced B4 reinstall (@ least IMHO). 7. Depends....if the 2.2. is over 150K, probably. But wouldn't bother otherwise.....(I'm a hypocrite...my '96 EJ22 w/128K has a bad valve guide...so....yeah.) 8+. The 2.2 / EJ22 only had EGR on the AUTOMATIC-equipped engines. All EJ25's do/did. You CAN make it work w/the non-EGR port heads w/out drill/tapping.- Search for my post on it. 9+. Read up on what HG to use....it'll need to be a 2.5 bore, but there may be better versions for you....FRANKLY. BTW, Your '99 EJ25D is actually a 'hybrid' year, as it has the Phase 2 block w/the Phase 1 DOHC heads GL, Td Edited August 25, 201510 yr by wtdash
August 25, 201510 yr I have a set of the HG you need to do this conversion. $20 less then costs. I got them, the box is still closed. Larry
