The darned choke cable 85 1.8 gl touringwagon
Hi there
Recently bought a 1985 1.8 gl
Touring wagon sunrasia rims tall roof
225 on clock 350$
One or two problems like the heater busted inside car and fluid all over passenger floor
By passed the heater
Any hows cant get it started rather starts and stops
Had good look and the chike cable is loose
Yes goid old choke cable
Cant find a pic anywhere even in repair manual of where the darned thing goes
Love to see it going again
Any one with any ideas id love to hear from u
Save my suby
Also have a 1993 sportswagon which i am working on
Some idiot at a repair shop used a impact rattle gun when removing spark plugs and stuffed the threads i hope helecoils will work
Anyone had anyluck with helecoils on a aliminium head
Love yhe subys cant wait to see seven mile beach a fishing tod or two and a bbq
Thankyou to whoever could help with either question
Aussydan
The 1985 Touring Wagon, has the EA82 engine, or the EA71? ... :confused: ... The Manual choke was used by Subaru on their EA71 engined Touring Wagons; I kindly suggest you to share some photos of your wagons here, so we could help you better.
... Some idiot at a repair shop used a impact rattle gun when removing spark plugs and stuffed the threads ...
Yes, that is Horrible! ... :eek: ... If the thread stripping was too Rude, I bet you'll need to send the Heads to a Repair Shop, in order to fill the openings with Aluminium and redo the Threads...
Good Luck! ... Kind Regards.
Rude isn't quite the right word to use there, I think what Jes means to say is if the damage to the threads is too severe, you'll have to have them repaired at a shop. Just a friendly correction jeszek, your English is very good, "rude" just isn't the right adjective for that. :-)
Edited by l75eya
Correction accepted.
Usually I use the same adjectives that we use in Spanish,
and some of them has different meanings in English, sorry.
I was trying to say if the stripping was done very violently...
Kind Regards.
Kindest regards to you, too, Jes. I hope all is well.
And back on topic to the original poster, I echo the desire for pictures! A stock manual choke ea82, or is it an aftermarket setup?
I only have seen Stock Manual Choke on EA71 engined, third gen Subaru Leone:
Note the "Manual Choke" Control on the Dashboard: it was a 1.6L (EA71) Gen III Leone DL (Manual Windows)
But it had the Optional Wooden Steering Wheel.
85 model EA82 had the semi-auto choke here. It's the only model that did. My first subie was an 85 sedan with this type of choke.
Because it's so rare, the repair manuals don't cover it.
What is meant by "the cable is loose"?
The lever you pull on is attached to the cable by a small grub screw underneath. The cable box itself is held on by the round plastic grommet on the front (hidden behind the lever) unwinding off the surround.
How many k's on the 93 model? I know someone in Qld who's got a sportswagon they're stripping. He (well his wife) might be interested in getting rid of the engine block (or complete engine). Got to be better than working on a helicoiled spark plug. I'd also worry about it coming loose again...
Same guy has a really rusty 85 touring wagon with the manual choke he's stripping. so if your cable is stuffed, I can ask him.
Edited by wagonist
  • 2 months later...
Found a best Picture of the Choke Lever on an EA82:
Any Updates for this thread?
Exactely the same on the 3rd gen 86 Leone (GL) Ea82 Wagon I had.
The choke cable needs to be adjusted / shorted to take up / readjust   slack at carb,
need to take off aircleaner box to do this. make sure choke butterfly fully open with choke off.
Also make sure to check readjust fast idle linkages to throttle butterfly. otherwise when you pull choke car won't run.
It should be be running at about 2000rpm at full choke then return to normal idling speed when choke off/fully pushed in.
Also found the manual choke far superior to the auto choke on later 88 Leone / GL I had also  especially for cold winter starts because of its better adjustibility.
Edited by subnz
Yes.
I shared those Photos here, because seems like the Manual Choke wasn't an Option for the EA82 in USDM, (maybe on the DL lineup?) but I found them on the LADM (Latin American Domestic Market) Specs' Subarus, as well in AUDM, NZDM, JDM, and certain European markets; However, this Manual Choke is more often seen on the EA71 engined, third gen Leones.
Kind Regards.
