Retiring '97 Legacy
Hi all, time to retire my '97 leggy, body is rusted along with door sill looking at a '99 175000 miles, mine had 250000, questions body on '99 is perfect no rust i dunno if HG has been changed, is that a concern on the '99's? i have factory on my '97 will that work in the '99? hate to let her go, but its time, thanks for your input :( i might pull & save the motor from mine, HG done 2 yrs ago
Yep, motor is plug and play.  Save the motor and any other good parts you may want.
Scrap the rest about $250 or so for the weight of the metal.
Thnx LMdew how bout the factory alarm, can i transfer it from a 97 to a 99?
a 1999 legacy will have an ej222, and the electronics are different than the 1997 ej22e.. A 1999 outback has the old style electronics and will swap with an ej22e
Does the 99 have a 2.5 or a 2.2?
If it has the 2.5 the 97 2.2 will bolt right in and plug right in, but if it's a 2.2 it will be different electronicaly. I beleive it can still be swapped, but its not plug and play.
id like to know about the alarm tho
Edited by djmark7
I think, if its a 2.5 the alarm should swap because the electronics are same.. The box is under the center console as I recall. I could be wrong..
If your engine swaps than the alarm will most likely swap.
A 99 Legacy will have the ej25, not the ej22. The electronics is the same. Pretty much plug and play, with a change needed on exhaust header, as they are not the same. But no big deal.
Yes head gasket problem is a potential problem on a 99 model 2.5 motor. All Legacy motors 2.5 from 1996 thru 1999 are the same design, so head gasket problem is there for all Legacy cars during those years.
right now there is no alarm in the 99 you think the wiring is there?
and does the '99 2.5 have the same HG issues as the '97 does?
Yes they are the same ej25d motor.
I would see how your alarm is installed, but if its factory than yes the wiring will more than likely be there.
sorry to bring this up again, the 99 is not an option now looking at another '97 however it does not have the cold weather pkg. (heated mirrors etc.) nor factory alarm it does have remote locking question is, do you think the wiring would be there for alarm & heated mirrors so it would be a matter of swapping the alarm unit and mirrors & switches? thnx again guys also the car i would be pulling it out of is a limited other car is not
Edited by djmark7
