December 4, 201510 yr Hello i have a 1992 Loyale recently replaced the power steering pump, and my steering still sucks anyone know why?
December 4, 201510 yr Most likely the proportioning valve in the steering rack has gone out. You can try jacking up the vehicle and turning the steering wheel lock to lock several times to make sure all of the air is out. If that doesn't do it, it's rack time.
December 6, 201510 yr did you bleed all the air out of the system? Need to turn full lock to full lock a number of times with the cap off and the engine running. Is it hard to steer all the time, or just for parts of the turn?
December 17, 201510 yr Author Only sometimes... Like when I'm at a standstill or going slow. And which cap? Pwr steering?
December 17, 201510 yr Yes, the power steering reservoir cap. The symptoms I suggest happen all the time regardless of speed, although you may not feel it as much once moving, but will definitely be noticeable.
