Power windows 88 GL wagon arent working
ive changed the switch in the door and the relay. should i get all new wires? i dont know what else to do. thinking i just might try to find some doors with manual windows. or maybe just a manual regulator and track for the inside? and help/suggestions are greatly appreciated.
  • 2 weeks later...
Id check the wiring splice under the passenger carpet if you havent yet. door jamb wires are possible too, but harder to check
Can you be more specific as to the location of the wires on the passenger side.
We also are trying to track down faulty window wiring
Thanks
Have you cleaned the switches? The contacts get coated with crud after time. Main controller is under the carpet under front seat. Both the switches on the door and main switch need to work for window to operate
Edited by wagonist
Btw, do the motors in the doors work? Unplug them and connect the battery directly to check
passenger front floorboards: all power and ground for windows splice off one (two actually, one power/one ground) 10 ga wire under the carpet. they are not sealed from the elements, just wrapped in tape... and soggy boots in the winter tend to soak it in salty water.
