December 29, 201510 yr Can I put 2.2 phase 2 heads from a 99 legacy on a 2001 2.5 block. The 2.5 has a broken timing belt and i have a new set of 2.2 heads sitting in my shop. Thanks
December 29, 201510 yr Author I know you can do it on the phase 1 motors with phase 1 heads. I'm just not sure about the phase 2
December 30, 201510 yr Phase II EJ22 heads are the same exact heads as Phase II EJ25 heads except for the exhaust ports. unlike Phase I - they have the same intake manifold bolt pattern, same valve part numbers, etc. you just need a single port exhaust header from any 1996-2001 EJ22.
December 30, 201510 yr you don't ''gain'' anything, reliability or power, by doing it. but since you have the heads you will save the cost of rebuilding the old heads. the y-pipe will cost you some thing though. but it will work.
