January 31, 201610 yr Went to check the oil on our forester, found coolant on the block. Factory spring-sheet-metal clamp had broken in 2 directly opposite the tabs, it really wasn't very rusty so can't blame that. Anyone ever see anything like that?
January 31, 201610 yr I've seen those rust in half, I've also seen holes rust in the steel pipe to the heater core. It has a T that goes off to the throttle body heater and they tend to rust right at that intersection.
February 1, 201610 yr Author Top hose at the block. Removed probably only once years ago when the dealer did the head gaskets under warranty (external oil leak, that is of course back).
