June 2, 200421 yr I'm looking for an OBDII reader. The ones I've seen so far are pretty expensive. Isn't there one that I can run on my PocketPC or Palm that just gives me the code(s) ? I can look up the codes on the web..... Any suggestions ? Rob.
June 3, 200421 yr same here, I'm still looking for an answer to my previous post on how to reset the air bag dash light also.
June 3, 200421 yr Author So far I found this: http://laplogger.com/shop_now.shtml and this: http://www.obdmeter.com/index.html BTW, can't you reset the CEL by disconnecting the battery, pumping the brake a couple times and leaving it for 30 mins ? I know it resets the ECU, not 100% sure if it will erase faultcodes though... Rob.
June 3, 200421 yr I bought a reader for about $129. It pays for itself in 2 uses (if you had to take it to a shop). Also Autozone reads them for free...............
June 3, 200421 yr $88 USA delivery.....$93 in Canada.....Have had it for 3 years now.....Works GREAT.... http://obddiagnostics.com/
June 3, 200421 yr Have a look at this. Software for your palm that gives you more than just codes. I've got a former version of it and am very satisfied. If things have'nt changed, Dan Harrison will promptly answer all your questions.
June 4, 200421 yr $88 USA delivery.....$93 in Canada.....Have had it for 3 years now.....Works GREAT....http://obddiagnostics.com/ Second that. With the beta software (v2.3) you will even read A/F sensor in newer Subs (2000+). Need a laptop of course...
