Do I need a map sensor?! Bogging issue @3k rpm
so really they could just do one cycle and thats it? i only get the p1101 code when i do that i feel like i should be getting alot of other codes since i dont have abs or any evap stuff for that matter. has anyone used a a stinger ems? seems like it would solve alot of my  problems. then later down the road i can get it retuned if i get another engine.
  • Replies 76
  • Views 8.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Fairtax4me
    Fairtax4me
    Rear O2 sensor doesn't make any difference for fuel trim. It's just a check sensor for the catalyst.   Can you watch the sensor data on your scanner?
  • heartless
    heartless
    we tried putting one of those cone type air filters on our dodge truck... ended up putting the stock air cleaner set up back on it... it ran ok, but didn't sound quite right... aside from that, I have
Posted Images
Also is there anyway to tell that i'm in "manual transmission" mode? i grounded pin 50 but i'm not sure if thats it or not i know 95 ecu's completley different than any other ecu's is pin 50 actually it for my car i cant find anything anywhere!
