June 17, 20169 yr I recently replaced the head gaskets, but the fans where working normally i believe. the only other thing i did was degreese and pressure wash the engine and bay. The fans go on from a cold start and stay on.. what should i look for? the wire is connected to the censer. fans are on so it has power. Any advice what it could be ? Thanks
June 17, 20169 yr they(or maybe just one on a 96?)may come on if the a/c is on - make sure it's off and try again? Edited June 17, 20169 yr by 1 Lucky Texan
June 17, 20169 yr If the AC isn't turned on then there may be a problem within the ECU. It controls the fan operation by making a ground connection which turns on the fan relay. If the diagnostic connectors are tied together under the dash that will do it also.
June 17, 20169 yr Is it throwing any codes? If the engine coolant temp sensor is bad or not connected the ECU will run the fans as a failsafe since it doesn't know what the temp is. There's two sensors - one for the gauge, the 'coolant temp sensor', which is not the sensor we're looking at/for. The other is the engine coolant temp sensor - that's the one I'm referring to. (Or as already mentioned if the a/c or defrost is on that will do it too). Edited June 17, 20169 yr by porcupine73
June 22, 20169 yr Gotta love those easy fixes. The fans will come on with the heat selector on defrost, too.
June 22, 20169 yr Author Gotta love those easy fixes. The fans will come on with the heat selector on defrost, too. Gotta love those easy fixes. The fans will come on with the heat selector on defrost, too. good to know. thanks
