August 3, 20169 yr I am flying down to San Diego to do a timing belt job on my buddies '96 OB because it's significantly cheaper than taking the car to a mechanic. I ordered the Lisle cam seal puller, but it's back ordered and not expected to delivered until after this weekend. I can use a pick, but I thought I would ask if anyone has made one. I was thinking of modding a butter knife or copper tubing. The copper wouldn't be a risk of scratching the cam shaft, but maybe somebody has a better idea (?)
August 3, 20169 yr I've never had trouble with a small flathead screwdriver and some needle nose pliers. I try to puncture the seal edge rather than keep it right on the shaft surface to get a little pry on it. Once it's out far enough to grab, the pliers do the rest of work.
August 3, 20169 yr I have removed seals from various things as folows: use a pick or other sharp thing and a small hammer to poke / start a small hole in the flat steel part of the seal. Then screw a long pointed sheet metal screw part way into the hole. Pry on the screw to lift the seal out.
August 3, 20169 yr Get your buddy to prime it to his house. https://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K
August 4, 20169 yr Hole in the outer flat section of the seal and then a screw into the hole +1 vote.
August 4, 20169 yr +1 to both of these, if parking, gas, plane tickets are worth the cost then what's $14? Get your buddy to prime it to his house. https://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K Hole in the outer flat section of the seal and then a screw into the hole +1 vote. i frequently do that as well - create a small divot in the face - then self tapping sheet metal screws carefully in the seal face and use those to pry it out.
