November 6, 20169 yr Hello does anyone know exactly where the extension spring, (that's helps pull the clutch fork back) connects to? Thanks
November 7, 20169 yr If it is an EA82 engined subaru, this post has a Photo that might illuminate your path: ~► http://www.ultimatesubaru.org/forum/topic/128564-help-remove-hill-holder/?do=findComment&comment=1168746
November 7, 20169 yr Factory Stock, the clutch return is done by the Hill-Holder cable and spring on 4WDs. FWDs had a return spring on the clutch fork and pitch-stopper bracket. If the H-H has been removed, a throttle return spring can be used, if one doesn't have the correct FWD spring handy.
