Clutch extension spring location
Hello does anyone know exactly where the extension spring, (that's helps pull the clutch fork back) connects to? Thanks
Factory Stock, the clutch return is done by the Hill-Holder cable and spring on 4WDs. FWDs had a return spring on the clutch fork and pitch-stopper bracket.
If the H-H has been removed, a throttle return spring can be used, if one doesn't have the correct FWD spring handy.
