November 23, 20169 yr Been looking into my steering wheel play on my GL but have no idea what to search for. The issue isn't in any of the steering components but the actual wheel shifts from one side to the other in the column. Especially noticeable since it doesn't have power steering. What would cause this? Whats it called so I can search and fix it?
November 23, 20169 yr Not sure if this is the problem your having. I had a slight amount of play if you pushed and pulled on the steering wheel. I found my steering wheel was loose on the shaft splines, the nut was only finger tight. Not sure if it got left loose or worked loose. Before I tightened it I made sure my steering wheel was centered to the steering rack.
November 23, 20169 yr Check the u joint from steering shaft to your rack. I've had that wear out and it caused a little binding and flip flopping of the steering wheel.
November 23, 20169 yr colemanapp has mentioned the steering u-joint and I think that my be my car's problem when it is not moving and the experience of having to turn the wheel hard. Someone before me removed the power steering components and 'manualized' it due to a leaking power steering hose and so it binds on turning the wheel while standing still. It seems fine otherwise but does have hardly noticeable freeway play. I would check it, still, it is a possibility. Edited November 23, 20169 yr by lrgvanman
November 23, 20169 yr If you mean the actual steering wheel shifts from one side of the column to the other as you turn, then your upper support bearing is toast. It may or may not be a serviceable part and may or may not still be available if it is. You'd have to call a dealer to check. if it is shifting like that, DO NOT drive it. The wheel could lock up on you and that would be no bueno. Easiest fix would be a used column from the jy.
December 13, 20169 yr Had this happen once and it wasn't anything major. I pulled the steering wheel there was a rubber bushing near the top that just had to be pushed back into place. I was worried it would work its way out again but its been three years so far and it's still fine.
