December 16, 20169 yr Well, thanks to my 08 with TPS I was alerted to the fact that the cold was wreaking havoc on my tire pressure. Checked the 05 (no TPS) and found was also suffering from cold symptoms. If you are prone to forgetfulness or "oldtimers disease" check your tire pressure if you haven't already. Edited December 16, 20169 yr by brus brother
December 17, 20169 yr A good reminder. Just today, my OBW tires looked a little low. Checked rears with gauge and found both at 24 psi. I always carry a cig lighter powered tire pump, so it is ez to pump up tires. If one seems to be loosing air too fast, then I check for a nail puncture, or suspect that crud has built up where the tire bead meets the alloy wheel. If so, it is off to the tire store for a 're-sealing" of the tire/rim to make things right again.
December 17, 20169 yr The Snow Shark attacked at Seaside Park just before dawn. They leave the gates open , or opened them just before I got there from the single tracks that turned around at the entrance. So it was fresh kill snow for the Shark! We made tracks and twisted and launched our way through those tracks and many more to follow. The grass at the west beach parking area was the feeding frenzy. The Shark enjoyed the exercise and meal of snow. Now wet stuff to wash it away. waaaaagh !!!
