Paperscale Posted April 6, 2017 Share Posted April 6, 2017 So, while I was driving my brat, I noticed the gas gauge seemed oddly low for having just filled up, and barely drive 35 miles. I filled up again and it took almost 2 gallons. There is also sometimes, but not always, a slight smell of gas, and I've looked underneath, but I don't see any drips or leaks of fuel. I know I need new tires, but I wouldn't think that would mean I get under 20 mpg. Maybe I'm paranoid? What is your average MPG for an EA81/ BRAT? Link to comment Share on other sites More sharing options...
bratman2 Posted April 6, 2017 Share Posted April 6, 2017 A 2-gal fill up is too small to figure mpg accurately. My Brat, owned for 20 years this year averages around 29 mpg. But, I do live in the sticks so hardly any stop and go traffic. Load, wind, gas, foot and traffic can make a big difference. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 6, 2017 Share Posted April 6, 2017 (edited) I've had a lot of EA81's and in mixed driving always got 25 to 27. Out on the highway could run upwards of 32. That's with a Weber. GD Edited April 6, 2017 by GeneralDisorder Link to comment Share on other sites More sharing options...
idosubaru Posted April 6, 2017 Share Posted April 6, 2017 that's not a diagnosis. if those are 35 stop and go miles to work and two off roading excursions with your buddies and kicking back the beers with Bon Jovi playing while the car idles at your favorite overlook - you're getting good gas mileage. but if you're smelling gas - have you looked under the hood for leaks? check with engine running. sniff from left and right side - which is worse? look at any connections that have been recently worked on - carb, engine pulled...you can even bend them where they connect a little and look for spray - this can amplify small leaks. if there's no obvious leaks then the obvious starting point with any gas engine like this is:1. is it carbureted? start there - that's usually the problem. 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 6, 2017 Share Posted April 6, 2017 Unless he has a turbo Brat it's carbed. Which means it needs a Weber. That's the only viable solution to the stock carbs at this point. Many have tried to limp them along but ultimately they end up with a Weber. GD Link to comment Share on other sites More sharing options...
